CBR 600 FX front brake problemo
sunbear
PostPosted: 19:12 - 02 Jun 2009    Post subject: CBR 600 FX front brake problemo Reply with quote
Hey fellas
Some of you may have seen my ad in the bikes and accessories listings. Here's a quick run down of what I am experiencing :
Front brake slows the bike down fine. At around 20mph and lower however, the front of the bike judders which gets worse as speed decreases and sometimes a "grinding" noise comes from the front wheel. Now, I thought it could be warped discs, however I get no pulsating through the lever. I have also had the front wheel in the air and the discs seem straight when turned. Everything is nice and tight.
The problem very temporarily disappears after I have removed the calipers from the disc and pushed the pistons back to get them back on to the disc. But after a mile or so they go back to the juddering business. With the front wheel up it does not spin very freely.
Any ideas where to start looking ? I have no idea about calipers and stuff.
Cheers Thumbs Up
Bikes had : BMW F650, suzuki tr50, gt125, SV400, GSXR600 SRAD. Honda CBR900RRP, CBR600FX, CBR1000F, VT600, Transalp 600, mtx125, nsr125r, CB500T, Yamaha fy50, tzr125, tdr125, XV535, Diversion 600, Fazer 600, TDM850 MK1 & MK2, Majesty 400, XV 1100. Cagiva mito evolution, Aprilia rs125, Piaggio x9 125. DNA 125 . Suzuki Bandit 600, GZ125 Marauder, RF600 , RF900RS2, Kawasaki ZZR400, ZX6R Ninja, ZZR600 . Ducati 750 Sport . Triumph Tiger 955i. CURRENT : 2004 Kawasaki Z750 and LOVIN IT !
Noxious89123
PostPosted: 21:06 - 02 Jun 2009    Post subject: Reply with quote
I have an F-Y and have EXACTLY the same problem. Had the problem with the standard discs and pads, and again with my EBC discs and pads.
Then front wheel will always have a little bit of drag as the pads are always in contact with the disc.
What pads are you using? I'm using EBC HH Sintered pads atm.
ZaphodBeeble
PostPosted: 21:41 - 02 Jun 2009    Post subject: Reply with quote
Probably corrosion built up in the calliper dust seals. The pistons are not returning fully when you let go of the brake lever. Personally I would pump all the pistons out and remove the dust seals to scrape all the corrosion out. Use red rubber grease to lube them back up when re-fitting. Remove a calliper and take some pictures with the brake pads removed from said calliper.
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
Noxious89123
PostPosted: 22:02 - 02 Jun 2009    Post subject: Reply with quote
Doubt it's that, I had my calipers split and cleaned just before winter, a few weeks after I'd had new discs and pads fitted and it was still doing it then.
I also recently had my calipers off and cleaned some of the crap off the pistons and put a little silicone grease of them. Doesn't seem to have made any difference.
alun111
PostPosted: 00:11 - 03 Jun 2009    Post subject: Reply with quote
Are you sure it's not tyre grip/headstock bearings/suspension/wheel bearings problems?
sunbear
PostPosted: 06:15 - 03 Jun 2009    Post subject: Reply with quote
Tyre grip is fine, new wheel bearings just before I had the bike, headstock bearings seem OK to be honest. The handle bars turn freely with no notchiness with it off the ground.
I am stumped !
Noxious89123
PostPosted: 20:23 - 03 Jun 2009    Post subject: Reply with quote
I am stumped !
Ditto. Also worth noting, it seems to be an intermittent problem, it doesn't always do it.
Sunbear, what tyres are you using and what pads ar you using?
I'm using BT-021s and front and rear are both rather squared off. Pads are EBC HH, and calipers were cleaned up within the last month or so. Maybe the pads aren't moving in the caliper properly?
The juddering feels almost as though the pads are sticking and releasing against the disc.
EDIT: Just found this, could be of some relevance maybe?
https://www.ducatisti.co.uk/forum/ducati-749/5128-ducati-749-brake-judder.html
Definitely check the head bearings. If they are OK and it still judders then the discs are the problem.
However, I had a similar juddering from the bakes on my ST4s which was definitely brake related as at very slow speeds with light braking I could feel a marked on/off effect as the wheel turned. I made sure all the buttons were clean and could be moved, with no improvement. I measured the runout for each disc with a dial guage and found that they were both under .004", so not much warp there.
Finally I took the discs off the wheel and scrubbed each of them with 200 grade wet & dry and then burnished them with a wire brush on the electric drill. Success - no more juddering.
My theory is that pad material builds up invisibly on the disc causing differing friction qualities around the rim. I think the possible cause of this is holding the bike on the front brake while the pads and disc are hot after a rapid stop. My work with the wet & dry removed this allowing the discs to brake evenly again.
I wonder how many discs are scrapped because they are "warped"?
Will have to try cleaning the discs and pads, could have some sort of contamination?
Noxious89123
PostPosted: 21:08 - 03 Jun 2009    Post subject: Reply with quote
Done a bit of searching on Google, and there seems to be quite a few ideas floating around about this.
The main thoughts seem to be head bearings or warped rotors. As we're both sure neither are the problem, I've been reading more into the other ideas people have.
A strong possibility could be cooked / glazed brake pads. Convieniently, I have photos of my pads;
https://img30.imageshack.us/img30/4277/1000812k.jpg
https://img37.imageshack.us/img37/3994/1000813.jpg
sunbear
PostPosted: 09:09 - 04 Jun 2009    Post subject: Reply with quote
Those pads resemble mine, but mine arn't as scored as yours seem to be . I cannot check the tyres or pads at present (at work)
Noxious89123
PostPosted: 21:02 - 04 Jun 2009    Post subject: Reply with quote
My discs seem to have alot of dark crap on the surface of them, with the odd light shiny line round them, so I think it must be from cooking the pads.
What is the best way to wear this off? Light braking, or heavy braking?
Bofh5
PostPosted: 08:43 - 05 Jun 2009    Post subject: Reply with quote
ive got a 95 FS and get the same sort of thing as well.
Is it like this example: Travelling along at say 70 and need to stop so apply brakes everything is fine then just before you come to a stop it feels like the front wheel is juddering almost as if the brakes are like abs (sorry crap example).
I changed my wheel bearings checked the headstock and had 2 mechanics look at it none of which could tell me anything.
I have some new carbon ceramic pads to put in soon so will see if these make any difference.
(L)users...Disk space is to good for them.
Bikes: Honda 50 / CB125-TDC / 93 CBR600 F2 (Stolen & Trashed) / 2001 SP-1 (Sold) / 95 CBR600 F3
sunbear
PostPosted: 15:46 - 05 Jun 2009    Post subject: Reply with quote
Yep, thats what happens with my bike too. Is this just a CBR thing ?
Bofh5
PostPosted: 16:00 - 05 Jun 2009    Post subject: Reply with quote
When i put the new pads in i'll scrub the discs and give the callipers a good clean and see how it goes.
Not really a huge problem more irritating than anything.
sunbear
PostPosted: 18:53 - 05 Jun 2009    Post subject: Reply with quote
At the end of the day the front slows me down, and the back brake will bring me to a stop. But as you say, it can be iritating. Would just be nice to find out what causes it !
temeluchus
PostPosted: 20:36 - 05 Jun 2009    Post subject: Reply with quote
you seem to have covered most propbabe causes.
One thing to look at is the brake disc bobbins holding the disc to the hub. They can corrode and cause odd sensations-perhaps you disturb em and they free when you get the caliper off and then return to a bad state after a few miles after refitting.....
Noxious89123
PostPosted: 21:14 - 07 Jun 2009    Post subject: Reply with quote
I have found the cause of the problem.
According to the internet, if you overheat the pads, they will deposit a fine layer of friction material on the surface of the disc. The adhesion between the pads and the discs is increased by the material stuck onto the disc, and so you get this juddering feeling at low speed.
I've been out for a ride recently, and using the brakes relatively lightly has removed the deposits from the surface of the disc.
The disc surface looked slightly darker, where the pads had left stuff on the disc.
Seems to fit Smile
There is a gap of 1 year, 86 days between these two posts...
maximi1ian
PostPosted: 14:28 - 02 Sep 2010    Post subject: Reply with quote
This brake judder has just started happening on my 2003 CBR600RR
It only occurs when braking hard from low speeds, eg 15mph-0mph. When in traffic etc. A violent vibration through the front forks that shakes the fairing and bars. Note: No feedback through brake lever.
Therefore I cannot see how it can be a wharped disk as so many people speculate. As it only happens very occasionally, and at low speed only.
However when it happens I immediately thought: Problem with brakes, its like one of the pads is vibrating in the caliper, bouncing off the disk, like it got stuck on the caliper pin and was at an odd angle (if that makes sense.)
The only changes to the bike I have made recently are increasing tyre pressures to 36/42, from 30/36. And softened up the rebound and compression.
Noone seems to have a definative answer to the problem but I will start by trying the suggestion above ^^ (cleaning disks). Also cleaning out the disk rivet/bobbins. Then I shall reset the front forks to the standard settings.
TUG
PostPosted: 14:48 - 02 Sep 2010    Post subject: Reply with quote
Juddering? Has anyone tried changing the fork oil in their bikes?
Haz ER-5, innit!
0l0dom0l0
PostPosted: 16:30 - 02 Sep 2010    Post subject: Reply with quote
Seems to fit Smile
that sounds like a reasonable explanation to me, but it doesnt, and wouldnt explain why the pads are overheating in the first place. you are using sintered HH pads and they are going to need some serious temperatures to overheat. have you checked the simple things like your resoviour isnt overfilled etc?
the only thing that could possible cause them to overheat is if they were rubbing, but i cant see how they can be without you noticing!!
maximi1ian
PostPosted: 17:45 - 02 Sep 2010    Post subject: Reply with quote
I just got back from a 20min test ride after cleaning out disk bobbins/rivets, a rinse with water and having reset the front and rear suspension to factory settings.
I was trying to prompt the bike into juddering by continually braking from 15mph or from 30mph, and even trying some higher speed braking (40/50mph) and I couldn't make it judder once.
Unfortunately this isn't conclusive because it only used to happen occasionally, so after a few hundred miles i'll post an update but it looks good so far.
Assuming juddering is eliminated, I suspect that the suspension alterations have made the difference as it certainly feels a lot firmer and more bumpy since I made the changes. I had previously dropped the rebound and bump stiffness and I noticed that both front and rear the preload was set softer than factory settings (previous owners doing). Perhaps I was bottoming out the front shocks?? I am 6'2" and 85kg so I imagine the low front preload wasn't doing me any favours.
Still, to anyone experiencing this problem I would reccomend going through these stages before replacing various parts.
P.s
After cleaning I noticed some rotational movement (circa 1mm) in the brake disk (play in rivet/bobbins) is this normal? My hornet has no play whatsoever.
I am running road pressures (36/42) on pretty scrubbed Dunlop Qual. RR's and factory forks, pads just replaced (Brembo Sintered), fluid changed and calipers cleaned recently. No noticeable head bearing play.
Noxious89123
PostPosted: 12:18 - 03 Sep 2010    Post subject: Reply with quote
Shouldn't be the forks, mine have been rebuilt with new oil and seals. They also feel sweet, not harsh and bumpy, or soft and wallowy.
The last post was made 15 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 119.93 Kb
