rs50 - some problems
Moukdan123
PostPosted: 10:40 - 03 Jun 2009    Post subject: rs50 - some problems Reply with quote
I bought an '02 rs50 a couple of weeks ago and i'm having a couple of problems with it when i first got bought it, it had trouble starting so i bought a new battery for it and now it starts fine but i was riding it yesterday and as i was riding it the bike just died everything just went as if the fuel wasnt on and wouldnt start up again so i left it for a few minutes and tryed again and it started rode it about 25ft up the road and it did it again so i walked it home but at the moment and when i got back it started fine after that but i wouldnt be able to pull away the engine just cut out as soon as i got the bite can some one please give me some insight as to what might be the problem as i know very little about engines thanks.
Hutchysrs50
PostPosted: 01:13 - 04 Jun 2009    Post subject: Re: rs50 - some problems Reply with quote
Hi, when you say just died, did it go off instintly, or the revs dropped and it cut out?
iv done both so heres a solution to both.....
if everything just went off - all power etc.. the wiring is usualy earthing on the frame, check the harnis.
if the revs dropped and it cut out, you NEED to clean your carb, the symtoms your saying are pretty much spot on for a blocked carb, there will probly be a piece of dirt in the petrol flow, so when you ride, not enough petrol gets into the bike, but if you leave it to settle, the carb fills up enough for you to ride for a few minutes.
Gilera SC 125 - Current
Moukdan123
PostPosted: 14:24 - 04 Jun 2009    Post subject: Reply with quote
Hi, the revs went down and then cut out. it has petrol in the tank and the tap was on but it hasn't got a choke at the moment but i am searching for one thanks for the help
Bikes - 02 Aprilia RS50 - 89 Kawasaki AR125
Hutchysrs50
PostPosted: 15:32 - 04 Jun 2009    Post subject: Reply with quote
clean the carb, im about... 90% sure it will solve your problem.
Hutchysrs50
PostPosted: 16:19 - 04 Jun 2009    Post subject: Reply with quote
how can it not have a choke? its a big part of the carb.
mine didnt have a choke on for over a year.
Hutchysrs50
PostPosted: 16:23 - 04 Jun 2009    Post subject: Reply with quote
what did you use to fill the big hole then??
a big screw
Moukdan123
PostPosted: 18:50 - 04 Jun 2009    Post subject: Reply with quote
So far as i know it hasn't got a choke it just came off or something like that or thats they said when i bought it anyway but i dont know what im looking for so im guessing it hasn't got a choke anymore. It's also got a full arrow exhaust system on it so i dont know if that might have anything to do with the choke or not i'm not sure but thanks for all the help and suggestions.
Hutchysrs50
PostPosted: 19:49 - 04 Jun 2009    Post subject: Reply with quote
CHR15 wrote:
take the carb out, take some pictures of it from different angles, post them on here, we'll have a look and if you dont know how to take it apart, that can be explained easier with pictures.
sounds like a plan to me! Thumbs Up Karma
Moukdan123
PostPosted: 18:11 - 28 Jun 2009    Post subject: Reply with quote
Hi,
Sorry i haven't replyed on here for a while ive been really busy and just haven't had the time but i did manage to take my rs apart and had a look at the carb and there is nothing rong with it looked at the filter and the float needle and bowl and they are fine but i did find out the bike was being starved of fuel because the fuel tap on the tank doesn't let any petrol out when its switched on so im running it on reserve at the moment.
Thanks for all the help guys
The last post was made 17 years, 75 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 61.63 Kb
