| flyingmythos |
 flyingmythos Two Stroke Sniffer
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 00:41 - 31 May 2009 Post subject: |
automatic CCT's adjust to account for cam chain wear. they dont move in and out, just out.
on auto ones, the spring can wear out, meaning it doesnt extend properly, causing the rattle.
manual ones have to be set right, but they work better if done properly. they need adjustment fairly often though (like every few thousand miles, depends how you ride).
if you do get a manual one, can i reccomend that you DO NOT buy one from bigccracing... they are dickheads. www.debben.co.uk is your best bet. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Pete. |
 Pete. Super Spammer
 Posted: 08:58 - 31 May 2009 Post subject: |
Manual CCT's have to be set carefully to avoid excessive stress on the camchain. Most people have them too tight. ____________________ a.k.a 'Geri'
| flyingmythos |
| sickpup |
 sickpup Old Timer
| flyingmythos |
| flyingmythos |
| Timmeh |
 Timmeh World Chat Champion
| flyingmythos |
| prawny1 |
 prawny1 World Chat Champion
| MaybeGuy |
 Posted: 16:23 - 05 Jun 2009 Post subject: |
if the cam chain snapped on the home made one, its not the CCT at fault then is it it was probably too tight.
theyre not complicated. i was considering making my own manual one for the GSXR and the R6, but its easier just to spend £40 on one. if you do get one made, make sure you use an o ring to stop the oil working its way through the threads.
adjusting them is generally easy too. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| prawny1 |
 Posted: 16:28 - 05 Jun 2009 Post subject: |
| mattsprattuk wrote: | if the cam chain snapped on the home made one, its not the CCT at fault then is it  it was probably too tight.
adjusting them is generally easy too. |
I know the guy hads overtightened his chain, my point is its not worth messing with home brewed tensioners, a proper tensioner is designed to keep the chain at the correct tension instead of the owner guessing with a manual one |
| temeluchus |
| MaybeGuy |
 Posted: 17:01 - 05 Jun 2009 Post subject: |
| prawny1 wrote: | | mattsprattuk wrote: | if the cam chain snapped on the home made one, its not the CCT at fault then is it  it was probably too tight.
and your saying this guy worked in a bike shop??
name and shame so people who use mechanics can avoid... ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
The last post was made 17 years, 131 days ago. Instead of replying here, would creating a new thread be more useful? |
