gear slipping
reu
PostPosted: 21:37 - 04 Jun 2009    Post subject: gear slipping Reply with quote
basically when im in 5 flat out and clutch in and shift into 6th it sometimes goes in then i go to let the clutch out like you would and it jumps outer gear again what is it?
125cc Pitbike <sold> Aprilla Mx50 <current>
PostPosted: 21:56 - 04 Jun 2009    Post subject: Reply with quote
Hi, first thing is to check your chain is at the correct tension. If thats ok then its likely to be worn dogs on the gear pinions, or the stopper arm isn't seating properly. Or if its a Honda then be firmer with your boot Wink
Pat
Information from Haynes manual
Hutchysrs50
PostPosted: 22:05 - 04 Jun 2009    Post subject: Reply with quote
seems to be a common problem with aprilias, speicaly there AM6 engines.
i cant imagine the cogs being warn out since its only 5th and 6th gears, im sure the first 4 get more use than 5th and 6th.
its usualy down to dodgy engine re-builds from there garage rather than a shop doing it.
Gilera SC 125 - Current
The Artist
PostPosted: 22:11 - 04 Jun 2009    Post subject: Reply with quote
The AM6 engine is not "aprillias" it is made by Minarelli but used by many manufacturers, all of which probably use the same factory anyway.
It is most likely you haven't clicked it into gear hard enough, if it is not that then it is either you or previous owners ragging it, not using the clutch properly and generally fucking it up.
Glad to be of assistance
Faraz
PostPosted: 04:45 - 05 Jun 2009    Post subject: Reply with quote
Very common problem. Havent come accross an AM6 engine that doesnt do it.
Down to people ragging them and doing shit gear changes etc.
Most of the AM6 engines do it because most of them have been owned by people who rape the shit out of their gearbox.
'56 Yamaha MT-01
'05 Nissan 350z Roadster GT
3 words dude.. Fvck. Yes.
Hutchysrs50
PostPosted: 11:09 - 05 Jun 2009    Post subject: Reply with quote
CHR15 wrote:
mine didnt Mr. Green and allymoss will agree, it was the smoothest box on a 50 either of us had ever seen.
sounds like you got lucky, what bike was it?
Hutchysrs50
PostPosted: 12:06 - 05 Jun 2009    Post subject: Reply with quote
CHR15 wrote:
gilera gp50, basicaly a gpr, but stripped down and rebuilt using better parts, they made 1000 dunno how many got into the uk mine was no. 284
then your some1 i should be talking to!
iv just bought a gilera sc125 basicaly a derbi gpr 125.
what where they like, reliable etc.. and majour problems with gilera?
Hutchysrs50
PostPosted: 12:46 - 05 Jun 2009    Post subject: Reply with quote
CHR15 wrote:
nothing really major, stick braided lines on if not already there, change the pads, fit a bigger carb, derestrict the pv, new exhaust?
build quality looks ok, but that means nothing if the previous owners were twats.
im keeping the exhaust stock, there like £300 anyway, will keep the carb stock but upjet a few sizes, you only need a fuse for the powervalve.
if you de-restrict the exhaust, airbox and put the fuse to work the powervalve, they make up 25bhp, so thats sound.
also, its still under warranty for 2 month or 14th month, not sure if you get 1 year or 2 year warranty with em.
Hutchysrs50
PostPosted: 12:50 - 05 Jun 2009    Post subject: Reply with quote
CHR15 wrote:
if your not changing the exhaust or air box wh do you need to re jet?
cos im taking the restrictors out the exhaust and activating the powervalve.
The last post was made 17 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 61.5 Kb
