NSR 125 R1 cylinder
steven843
PostPosted: 17:04 - 04 Jun 2009    Post subject: NSR 125 R1 cylinder Reply with quote
Hi, I have the uk spec 2001 nsr 125 r1. I recently had to get a new piston and cylinder. When i took the old one off it had a D code on the bottom. I brought a new one (genuine honda parts) and this one has a C code on it. After doing some research I found that there is an A,B,C,D,E available for the nsr 125. What i want to know is what is the difference between the codes and how do they affect your bike? many thanks. steven.
buddy
PostPosted: 17:09 - 04 Jun 2009    Post subject: Reply with quote
im not 100% but i think that they are SLIGHTLY different bores, for when ya use oversized rings and stuff
When this baby hits 88 miles per hour... you're gonna see some serious shit.
alains
PostPosted: 18:07 - 04 Jun 2009    Post subject: Reply with quote
yes , the difference is about 0.005 mm by letter
here is the chart . a C in a D is OK
steven843
PostPosted: 19:36 - 04 Jun 2009    Post subject: Reply with quote
So is there a power difference between a and e. What is the difference between the letters. thanks.
steven843
PostPosted: 19:40 - 04 Jun 2009    Post subject: Reply with quote
sorry i meant here not what is the difference because that would be a 0.005 bore size difference but why do they have different sizes and do they give a power difference at all or is there something else that each code does? many thanks. steven.
alains
PostPosted: 21:38 - 04 Jun 2009    Post subject: Reply with quote
no difference . as the coating is very hard the thicness must be marginaly different this why they made different pistons and the barrel determines the piston size . it's acceptable to re-fit a piston with a letter + or - without unconvenience
steven843
PostPosted: 18:55 - 05 Jun 2009    Post subject: Reply with quote
ok but why did they make five different cylinders then and is it just the nsr 125 that has this?
alains
PostPosted: 01:01 - 06 Jun 2009    Post subject: Reply with quote
no they dont make different barrels , they fit all barrels with different pistons . you cant find different barrel , you will only find the kit or the piston alone . honda says :
- 12000 kms (7500 miles) rings change with de-coking and you must look the letter under the barrel (you are obliged to dismount top-end)
- 24000 kms (15000 miles) piston-rings change with de-coking (so if you have done what i said you can order your spares first)
- 36000 kms (22500 miles) top-end change
you may do not respect this schedule but it's at your own risk . regarding others 2 strokes bike price of spares are not very expensive
steven843
PostPosted: 15:38 - 06 Jun 2009    Post subject: Reply with quote
ok last question cos i think i get this now, does it matter what code you put in your bike? also do just nsr's have this code systems, many thanks alains
alains
PostPosted: 17:23 - 06 Jun 2009    Post subject: Reply with quote
no matter you fit what your provider send you
The last post was made 17 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 64.9 Kb
