Tinnitus
crazymotorbik...
PostPosted: 19:30 - 05 Jun 2009    Post subject: Tinnitus Reply with quote
Hey,
I've had pretty bad tinnitus in my right ear for 2 weeks now. I woke up one morning and there it was!
I look after my ears, wear earplugs on the bike/pub/clubs, don't listen to my music too loud.
I went to the doc who suggested allergies and have been on anti histamine since. It hasn't really made a difference. I've never suffered from allergies (that i'm aware of). However during the recent warm weather we've been having I have noticed my hearing has diminished and i've felt bunged up.
Just before I got this problem i was also under a lot of stress, court case etc
I've suffered from mild hissy tinnitus for some time which I never really noticed, however this new frequency is driving me crazy! I cant stop putting my hands over my ears to check its level!
Just after some advice. What do you other sufferers do to help yours?
Shaun.
Bikeless
PostPosted: 19:40 - 05 Jun 2009    Post subject: Reply with quote
Suffered for years,you are not alone.If i think about it,it bothers me more so i try to distract myself.Also using background noise helps mine but if i'm somewhere quiet it can drive me up the wall.
MaybeGuy
PostPosted: 21:20 - 05 Jun 2009    Post subject: Reply with quote
you wear earplugs in pubs and clubs???
Laughing Laughing
crazymotorbik...
PostPosted: 21:40 - 05 Jun 2009    Post subject: Reply with quote
Sure do Very Happy
And before you start thinking I'm some kind of weird loner who goes into night clubs to hide in a corner...I'm actually engaged and living with my Fiancé.
Hope you never get tinnitus. Thanks for the not so helpful comment. Shame BCF is so full fo your type these days!
Shaun.
PostPosted: 11:57 - 06 Jun 2009    Post subject: Reply with quote
I've had it in my right ear for a couple of months, a constant white noise sound. I'm also slightly deaf in my right ear which came at the same time as my tinnitus.
I went to the doctors on Tuesday, he syringed my ears out (some nasty stuff in there Sick) but it made no difference. He told me to put warm olive oil in my ear every day for the next 2 weeks and see if it improves, if not he'll refer me to the ear clinic. I do wonder sometimes about my doctor.
The loudest thing I listen to is wind noise on the 'bike because I can't stand having ear plugs in. I got my deafness and tinnitus half way through a 6 month break from bikes so really doubt it's that.
I've just put it down as one of those things. You get used to it.
Tarmacsurfer
PostPosted: 12:45 - 06 Jun 2009    Post subject: Reply with quote
The olive oil softens and breaks up waxy deposits deep in the ear canal and allows it to slide out, it works. Your doctor isn't mad.
I'm immortal. Well, so far.
Clanger
Stirrer
PostPosted: 13:25 - 06 Jun 2009    Post subject: Reply with quote
Yes, I have a mild constant sound in both ears. And yes I used to go to clubs/festivals/rock concerts and not protect my ears.
It's totally my own fault. But I can usually fade it out, I only hear it if I'm doing absolutely nothing, and right now because I am thinking about it!!!
But generally it's not a problem. And I do protect my ears as much as possible now, to stop it getting any worse. Smile
PostPosted: 13:57 - 06 Jun 2009    Post subject: Reply with quote
I understand that, but it's not going to help with my tinnitus and my ears are clear of wax. So why I have to do it for 2 weeks and then go back to him if it hasn't improved is weird if you ask me. Why not just refer me straight to the ear clinic?
Bikeless
PostPosted: 14:19 - 06 Jun 2009    Post subject: Reply with quote
He's just checking if you still have blocked ears before seeing if you really have ear damage.
Tarmacsurfer
PostPosted: 14:21 - 06 Jun 2009    Post subject: Reply with quote
There's no guarantee that syringing will remove all of the deposits internally, there may be a particularly hard plug at the top of the canal behind a constriction (some people have narrow points in the ear). If that's the case you'll be referred to an ENT specialist to check out the situation and be dealt with accordingly if it continues after your olive oil administrations.
Good luck with it Smile
PostPosted: 14:29 - 06 Jun 2009    Post subject: Reply with quote
He looked in my ear with his little tool and said there's only a couple of flakes in there now. Oh well, maybe I'll try some later but I just can't be bothered warming it up.
Tarmacsurfer
PostPosted: 14:39 - 06 Jun 2009    Post subject: Reply with quote
It only really needs to be body temperature. Pour some into a little phial or a small bag you can seal and carry it around stuffed down the arse crack of your underwear to keep some on hand and at the right temp.
Simples Very Happy
plugger147
PostPosted: 01:13 - 07 Jun 2009    Post subject: Reply with quote
I have suffered with this on and off for the last few years, without meaning to scare or worry you if you have any type of hearing loss I suggest you press the need to see an ent doc to your gp asap.
Mine is caused by a tumour called an acoustic neuroma on the left side of my brainstem, if you have no hearing loss then you don't have to worry, if you do then it's not as bad as it sounds and can be treated well.
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
LimehouseCBF
PostPosted: 12:05 - 08 Jun 2009    Post subject: Reply with quote
Things with stuff like this is they cant provide a time when or if it will get better
I had glue ear for about 2 months which meant i was practically deaf for two months - so what did the doctor do? prescribed me a nasal spray?? its all linked up, so if your congested in your nose or coughing up flem apparently this also affects
well anyway i thought it was odd, she said to me it can go in 5 minutes to 50 years, thanks..
Id just take your doctors advice and be patient and keep going back if it gets worse.
And on the 7th day the lord said..lets get pissed
The last post was made 17 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 81.93 Kb
