flat spot
lroy
PostPosted: 16:39 - 05 Jun 2009    Post subject: flat spot Reply with quote
Hi all i have a gsxr 600 srad track bike it has a really bad flat spot between 7000rpm and 9000rpm its fine up to 7000rpm then goes really flat and struggles to get to 9000rpm then it clears and is fine again the exhaust has soot on the end can i think the carbs need setting up does anyone no about this or have any info many thanks
temeluchus
PostPosted: 19:27 - 05 Jun 2009    Post subject: Reply with quote
Youll need to take a peek at the sparkplugs really as soot on an exhaust silencer is normal.
Try a plug chop-this could be tricky on a full faired bike but can be revealing. Find a quiet bit of road, get it up to 8000rpm and kill the engine. Coast to a stop and check one of the plugs.
Once you get the plugs out and establish if its a rich or lean flatspot, youll then need to get some adjustment done-I dont know which GSXR600 you have, so not sure whether you are carbed or injection. Rich is black and sooty, lean is very light grey or white.
If you are blessed with carbs, you can adjust the needles-higher for richer, lower for leaner. Messing with the mixture screws will make little difference as they are for idle.
If you still have issues and its running rich, one thing to check is the air filter-this can become blocked and cause rich running.
If lean then make sure everything is fitted properly and there are no air leaks in the inlet.
lonner
PostPosted: 07:12 - 06 Jun 2009    Post subject: Reply with quote
hi
more than likely its just not dyno'd to run the race can you probably have as you nearly always get a flat spot somewhere in the rev range so try it with a standard can or a baffle and see if that cures it.
then you will know its the can as most likely cause as it runs well every where else.
hth
Ben.
PostPosted: 10:48 - 06 Jun 2009    Post subject: Reply with quote
get you carbs done, its either under/ over fueling because youve changed the air fileter or can or something like that, or the needles worn and needs replaceing.
follow my racing season
Race bike - R6
Road bike - sv650
temeluchus
PostPosted: 16:00 - 06 Jun 2009    Post subject: Reply with quote
zzr lon wrote:
hi
hth
You can adjust the flatspot out with a little fiddling. How do you thing they do it down the dyno shop anyhow? Its perfectly possible to tune the bike yourself with a little patience.
Most likely its a litte lean if hes stuffed a loud can on there, so raising the needles should get rid of the flat spot as this adds fuel in the midrange.
Ariel Badger
PostPosted: 16:11 - 06 Jun 2009    Post subject: Reply with quote
At 9000 RPM it will be needle hight, after that you are on main jet.
temeluchus
PostPosted: 16:15 - 06 Jun 2009    Post subject: Reply with quote
lol yeah thats what i said!
lroy
PostPosted: 16:28 - 06 Jun 2009    Post subject: Reply with quote
i have booked it into the garage today they have a dyno so they should sort the problem out they said it sounds like a fuel/carb problem thanks alot for all the info and help
Blue_SV650S
PostPosted: 08:44 - 07 Jun 2009    Post subject: Reply with quote
When was the last time you chanced the airfilter?
Are all the 'ram air' ducts secure/sealed?
lonner
PostPosted: 10:19 - 07 Jun 2009    Post subject: Reply with quote
Temeluchus wrote:
zzr lon wrote:
hi
hth
You can adjust the flat spot out with a little fiddling. How do you thing they do it down the dyno shop anyhow? Its perfectly possible to tune the bike yourself with a little patience.
Most likely its a little lean if hes stuffed a loud can on there, so raising the needles should get rid of the flat spot as this adds fuel in the midrange.
as he doesn't have your in depth knowledge he has done the sensible thing and let someone who has the knowledge and the equipment to sort the fueling propperly .
why do people think they can do what a very expensive machine and user experience does with a screw driver and a plug check.
its a guess and that is all it is and done badly will result in a fooked engine and a very large bill. Thumbs Down
The last post was made 16 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 65.56 Kb
