Focus Brakes Siezed/Broken
MarkJ
PostPosted: 21:36 - 05 Jun 2009    Post subject: Focus Brakes Siezed/Broken Reply with quote
I was going to put this in the workshop but that section seems more bike related.
I've been a bit of a plonker - I recently started a new job which gave me a company car, so my 04 Ford Focus Estate has been in my garage un-moved for around 6-7 weeks. Stupidly I put the handbrake on when I last put it there.
I've now come to move it and the car felt as though one of the wheels was dragging - no problem I thought, my garage is quite narrow and something's probably under one of the tyres, I'll just drive over it (nothing dangerous in there, I've got a few pieces of fake plastic coal lying around from an old electric fire/heater). About a meter later I get a sort of popping sound from the rear passenger side, and the car starts to roll freely. However when I come to press the brake the pedal it goes right to the floor. I pump it and immediately the brakes bite as they should.
Now I stop and go to reverse it back where it came from, and the brakes will bite fine if I keep tapping them as I slowly move back but every now and again the pedal will drop to the floor. You can see a drag mark where the rear passenger side wheel has been dragging. I have jacked both rear wheels up and they both spin freely and the same as each other.
To my knowledge the rear wheels are drum brakes. Does anyone know what I have broken and how to fix it?
Many Thanks
10 pence Short
PostPosted: 22:18 - 05 Jun 2009    Post subject: Reply with quote
The friction material will have corroded to the drums with the handbrake being left on. Moving the car may of released the bonding of the friction material so it has now seperated from the metal part of the shoe and broken up inside the drums. The pedal needs to be pumped to take up the slack where the material used to be. Take the wheels and drums off you should see whats gone on. Might of popped the wheel cylinder too. Thumbs Up
I haven't had a cont all day, drinkstable.
colin1
Captain Safety
PostPosted: 01:48 - 07 Jun 2009    Post subject: Reply with quote
i dont know about cars, but im surprised that it would do that after just 6 or 7 weeks
R6jonny
PostPosted: 02:08 - 07 Jun 2009    Post subject: Reply with quote
Brakes on my car seized after a short period too, mind you most of the car seized too...Sad
Honda NSR125 - Yamaha R6 - Ducati 748 - Suzuki GSXR750K6/GSXR1000K7/GSXR750K8 - Ducati 848 - Honda SP1 - Triumph Daytona 675
"simply because she is a female and is thus her actions largely make no sense whatsoever by default"
MattHirst
PostPosted: 08:47 - 07 Jun 2009    Post subject: Reply with quote
Drum brakes will seize up after only a week or so of being left stood still.
But i thought that Focus' always had discs front and rear?
Kwaks
I'm not a fast rider
PostPosted: 09:02 - 07 Jun 2009    Post subject: Reply with quote
Both my cars are left without handbrake on for the fortnight I am at work, otherwise they will bind.
As said, thought the focus was discs all round Confused
www.cliqueycuntsmcc.co.uk
MarkJ
PostPosted: 10:30 - 07 Jun 2009    Post subject: Reply with quote
Mine's the old style Focus Estate, and also the base CL model so just drum brakes.
It's at the garage now anyway so he'll sort it. The annoying thing is that I know not to put the handbrake on when leaving it for a while yet I still bloody did it!
colin1
Captain Safety
PostPosted: 11:32 - 07 Jun 2009    Post subject: Reply with quote
bloody hell cars are shit arent they. I would never have guessed they design modern cars that cant have the hand brake left on. How the fuck are you supposed to leave it parked without using a hand brake ? Ridiculous. Do they expect you to use chocks like with old aeroplanes or something ?
mistergixer
PostPosted: 12:36 - 07 Jun 2009    Post subject: Reply with quote
You can just leave it in 1st. Pretty simple really.
I always leave my cars parked in 1st after owning a 'Rocco with a weak handbrake - watching your car start to roll slowly backwards after you've just got out and locked up is not amusing*, neither is having to jog alongside fumbling with the key to the door before jumping in.
*It is highly amusing for any passers-by, however.
Space Monkey #7
Stelmer
PostPosted: 13:17 - 07 Jun 2009    Post subject: Reply with quote
I'm one for leaving vehicles in gear too. Usually 2nd.
I'd be inclined to check all 4 brakes.....
Or, if you have a few quid, take it to a garage and get them to do a brake check and clean. Do not tell them it's been stood as they could attempt to rip you off with new pads/shoes.
MattHirst
PostPosted: 17:17 - 07 Jun 2009    Post subject: Reply with quote
You can park a car with the handbrake on, but not if you are leaving it for a long period of time. It also tends to be drum brakes that seize up rather than discs.
Also, it isn't anything to do with the design of the brakes, its just the properties of the metals/materials used. 2 different metals (generally the braking surface of a brake pad will have metal in it) will gradually 'fuse' (i know thats the wrong spelling) together if left for a while. Any 2 metals will, it just happens.
Also, it isn't just the pads/braking surface that binds to the drum, the cam thingy that forces the 2 brake shoes out into the drum will start to seize up and stop your brakes from releasing.
Obiviously day to day use of the handbrake involves putting on and releasing the handbrake every so often so it keeps everything moving and free. But left for a week or longer then they will start to seize up.
colin1
Captain Safety
PostPosted: 01:16 - 08 Jun 2009    Post subject: Reply with quote
i've just googled the rear brakes on my car, and fortunately, they are discs not drums
veeeffarr
PostPosted: 02:28 - 08 Jun 2009    Post subject: Reply with quote
Focus rear drums unless specced otherwise, the car has the Reflex pack or the engine is 2000cc.
iooi
PostPosted: 20:54 - 08 Jun 2009    Post subject: Reply with quote
Strip them down.....
My clios used to do this. Often freed by rocking back and forth.
Then it decided to lock the rear completly on one side. Thankfully this was right outside our house and not on the trip we had just made.
After 2 days of trying to get the drum off. I talked to my local garage who do the normal work on the car and they lent me a slide hammer to get the drum off....
Still took a hour of thumping it to get it right off, but what had happened was the lining had unbonded and jammed up....
The last post was made 17 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.15 - MySQL Queries: 13 - Page Size: 82.83 Kb
