| tshort2007 |
 tshort2007 Scooby Slapper
 Posted: 20:41 - 07 Jun 2009 Post subject: AR125 Gone BANG :( |
Finally fixed the problem with my AR running rich and misfiring, the coil pickup was loose!
So decided to take it out for a run
5 miles of gentle riding got the engine nice and warm, so decided to kick it a notch on the dual carriageway.
about 5 seconds later, a thud and a rattling noise occured, resulting in the bike not idleing, but still fine at high RPM (apart from the quiet rattling)
Got back to the garage, and pulled the plug, looked perfect, nice mocha coffee brown colour. Fearing shattered bearings, i proceeded to strip the top end. Took the exhaust off, and out fell a chunk of piston, and a bit of ring. Images attatched (hopefully)
It appears the piston caught the exhaust port on the way down, as the piston has been burred over the bottom ring, just below the missing chunk.
The ar125 engine uses a rotary valve, with the injection port at the side of the block, so the piston has no holes for the inlet port. However, where the split is in the rings has been installed to the wider exhaust port. Is this correct? as the piston has no markings for inlet
What would cause this to happen?
And does my barrel look ok to you?
Thanks for all your help today |
| ms51ves3 |
 ms51ves3 Super Spammer
| bmwsport |
 bmwsport Nitrous Nuisance
 Posted: 20:50 - 07 Jun 2009 Post subject: |
wow at least you did it properly lol, err the barrell doesn't look very good to me, is that a bit of plating missing just below the exhaust port? does the ar have a powervalve? is that ok? Check out the mikata thread in general, couple of us going through the top end rebuild phase at the mo lol |
| tshort2007 |
| tshort2007 |
| Kickstart |
 Kickstart The Oracle
| tshort2007 |
| Kickstart |
| tshort2007 |
| welshlad25 |
 welshlad25 Two Stroke Sniffer
The last post was made 16 years, 193 days ago. Instead of replying here, would creating a new thread be more useful? |
