Chain lubed with gearbox oil?
bmwsport
PostPosted: 16:41 - 07 Jun 2009    Post subject: Chain lubed with gearbox oil? Reply with quote
Guys,
Today i've cleaned my chain with wd40 and brake cleaner, then brushed on some fresh gearbox oil, is this suitable?
I've used chain wax before but found it makes a mess and makes the chain look shite!
Thanks.
PostPosted: 16:45 - 07 Jun 2009    Post subject: Re: Chain lubed with gearbox oil? Reply with quote
The bit I'd worry about is the WD40 (which is often used to clean oil off stuff) and the brake cleaner. Most engine-oily things should be fine to keep the chain lubed.
Oh and it seems using fresh oil is rather a waste, but if looks are important to you, <shrugs>.
Kwaks
I'm not a fast rider
PostPosted: 16:49 - 07 Jun 2009    Post subject: Reply with quote
Like G I would not recommend the WD40, it can penetrate past the rings and force out the oil.
Never had a problem using the waxes etc myself, but then again don't give a shit what my chain looks like
www.cliqueycuntsmcc.co.uk
bmwsport
PostPosted: 17:07 - 07 Jun 2009    Post subject: Reply with quote
ok cheers, i only used the wd40/brake cleaner to get all the rubbish off the chain.. i dont think it had been cleaned in a long time!
PostPosted: 22:46 - 07 Jun 2009    Post subject: Reply with quote
Gearbox oil is designed for extreme pressure applications and has a high shear resistance. Absolutely perfect for a drive chain in my book.
Lone-Wolf
PostPosted: 22:55 - 07 Jun 2009    Post subject: Reply with quote
Wotcha.
I've used gear oil for years - not had any problems yet.
Cheers.
L.W. - www.moonshiners.org.uk
PostPosted: 23:07 - 07 Jun 2009    Post subject: Reply with quote
Gearbox oil is listed in some bike manuals to use on the chain.
Mark65
PostPosted: 06:10 - 08 Jun 2009    Post subject: Reply with quote
Hiya
Clean with parrafin, lube with gearbox oil,wipe off excess with a rag (watch fingers).
Mark
PostPosted: 07:58 - 08 Jun 2009    Post subject: Reply with quote
WD40 is mostly a chemical very similar to kerosene / paraffin. As such I would be just as dubious about using it as WD40, and would't really want to use a degreasant on a chain anyway (if you wash out any lube from inside the O ring sealed parts it is not likely to get replaced).
To wash a chain just use a tooth brush and some oil.
PostPosted: 11:15 - 08 Jun 2009    Post subject: Reply with quote
Equally, if the WD40 can get in past the o-ring to wash the lube out, it isn't sealed properly and the lube was probably long gone in any case?
PostPosted: 11:52 - 08 Jun 2009    Post subject: Reply with quote
Very true. And if WD40 can damage the O rings then I would expect paraffin to do the same.
The last post was made 16 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 69.45 Kb
