Making MDF look nice/ Building a viv?
Hadies
PostPosted: 19:15 - 09 Jun 2009    Post subject: Making MDF look nice/ Building a viv? Reply with quote
Hi all. I'm planning to make a new vivarium for my snake as he's slighly out growing his current one. Would rather build than buy as for the size I'm making, 4 x 2 x 2 foot, it would cost ~250 quid. I have just bought all the MDF I need in the right dimensions for ~£30 quid. Runners and glass should cost £50 max.
Anyway, how would you make MDF look decent? I looked at fablon but was put off as its just a big sticker lol Do I have much choice?
Whats that wood effect decor you can iron onto chipboard etc to make it look nice?
Not really sure if this is random banter lol
Thanks in advance
Pickledswede
PostPosted: 19:44 - 09 Jun 2009    Post subject: Reply with quote
The iron on stuff you're talking about sounds like just a wood effect veneer, or possibly really wood veneer? Just a thin layer with some adhesive on the back which you stick onto the original piece.
Don't know much about any other options. Could paint it?
Drew This post is not being displayed because the poster is banned. Unhide this post / all posts.
Ariel Badger
PostPosted: 20:34 - 09 Jun 2009    Post subject: Reply with quote
Paint could harm your snake, take care.
Bendy
Mrs Sensible
PostPosted: 20:49 - 09 Jun 2009    Post subject: Reply with quote
Isn't MDF also pretty nasty toxic stuff?
Bendy
Mrs Sensible
PostPosted: 20:58 - 09 Jun 2009    Post subject: Reply with quote
You have to seal the bits you cut or something, don't you?
(vague recollection from 'Changing Rooms' MDF phase many years ago)
Hadies
PostPosted: 21:28 - 09 Jun 2009    Post subject: Reply with quote
Shit bendy you had me worried there lol
Thanks for the input guys. The b and q nearby didnt have much in. They had white contiboard which looked tacky and MDF looked better than chipboard so i went for it.
I'll probably end up going for melamine as it sounds like the easiest option. Hope its not too expensive.
Does anyone here own a snake/ reptile or even fish and have DIY'ed their vivs/aquariums? Im looking to make a 3d background rather than just having a poster stuck on. I've looked around on t'internet and a lot of people have used expandable foam and tile grout. Has anybody had any experiences with this? I'm a little confused as I can imagine all that stuff being quite toxic. . .
plugger147
PostPosted: 22:50 - 09 Jun 2009    Post subject: Reply with quote
I've built 2 for our beardies, well say built they are both converted tv type cabinets. I think I've only got pictures of the first one.
The Shaping I made from polystyrene packing then I mixed some kids play paint with pva and painted it over the shaping and walls. I learned a valuable lesson here and realised that any tiny little gap must be filled with expanding foam and cut to shape before painting cos the bloody crickets/roaches etc creep in and hide. While the pva/paint mix was still wet I got some kids play sand that I'd mixed with food colouring and blew it off a sheet of paper with a drinking straw to break up the yellow a bit.
Rocks and branches were collected from beaches and either boiled in a saucepan or soaked in a bleach solution and then baked in the oven.
I'll see if I can find the forum I wrote a better write up on and post up a link.
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
mcgoogle
PostPosted: 09:45 - 10 Jun 2009    Post subject: Reply with quote
if you use MDF it will definitely need sealing i used MFC(melamine faced chipboard) when i built my viv and cabinet, this is the same stuff they use when you buy vivs from the shop, you can get it in loads of different colours and effects. its not bad price wise either for 2 8ft X 2ft boards in oak was only £24 and had more than enough. if you can afford an extra couple of quid get the 15mm thick just for the extra strength.
let the grout dry paint it your chosen colour the seal it with yacht varnish and let that air out until you cant smell any fumes
ill try and get some pics for you later and good luck on the build definitley cheaper than buying ready made Thumbs Up
current bike - CBR600fv
Dischord
PostPosted: 10:47 - 10 Jun 2009    Post subject: Reply with quote
I know it's been said but for the love of god wear a mask when you cut the stuff, I was building an install for the car (chav) and that dust knocked me on my ass for about 4 days, nasty shit.
2012 KTM EXC 250
plugger147
PostPosted: 18:05 - 10 Jun 2009    Post subject: Reply with quote
If you are going to use yatch varnish then leave it at least 2 weeks in a well vented area with the lights/heat source's switched on. The heat will cause the release of more fumes and I wouldn't put an animal in there until I was 100% sure the fumes had cleared.
Flip
PostPosted: 19:16 - 10 Jun 2009    Post subject: Reply with quote
People here have made their own. Could be worth a look.
plugger147
PostPosted: 19:32 - 10 Jun 2009    Post subject: Reply with quote
Cheers flip, thats the one I used to post in. There are quite a few guys who've built some wicked viv's on there.
https://www.reptileforums.co.uk/habitat/94005-setting-up-beardie-newbie.html
Thats mine, check out the habitat section there's some good stuff in there.
mr jamez
PostPosted: 20:05 - 10 Jun 2009    Post subject: Reply with quote
The dust is quite harmful due to its high content of glue (formaldeyhyde) and how fine it is. The real danger behind MDF is when it gets burnt by high speed tooling, it lets of a carcinogenic vapour (so don't go near a bonfire with MDF on it!). The dust is irritating, but it is no worse than normal timber which is very bad for your health. Stuff like Iroko and greenheart will have you choking within a few seconds of breathing the dust, nasty stuff!
MDF looks fine painted, however to make it look like anything other than a cheap MDF cabinet the edges need to be lipped with timber. That way you get a nice keen edge rather than a fluffy rough arse mess.
The last post was made 17 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 90.61 Kb
