Bike vibrating abnormally
Newbiker0507
PostPosted: 09:55 - 10 Jun 2009    Post subject: Bike vibrating abnormally Reply with quote
My CG is vibrating abnormally ever since I took it on a ride to Nottingham (from London). It culminated in the Honda sign on the forks falling off mid travel.
Any ideas as to what maybe causing it?
dextersaurus
PostPosted: 10:10 - 10 Jun 2009    Post subject: Reply with quote
Have you replaced the fork seals recently?
Newbiker0507
PostPosted: 10:18 - 10 Jun 2009    Post subject: Reply with quote
I personally haven't, no.
dextersaurus
PostPosted: 10:21 - 10 Jun 2009    Post subject: Reply with quote
Well when it vibrates, is it at higher/lower speeds or is it at higher revs?
Mines vibrates quite a bit at high revs, and i can't vind anything wrong with it, engine mountings are all good so it confuses me but it stops after the bike warms up...
Dunc
Newbiker0507
PostPosted: 10:41 - 10 Jun 2009    Post subject: Reply with quote
Dunc
I would say it vibrates more at higher speeds and higher revs.
dextersaurus
PostPosted: 11:08 - 10 Jun 2009    Post subject: Reply with quote
Dunc
Vibration at higher revs, i.e full throttle from a traffic light as you pull away would mean engine damage or something wrong with it.
Vibration at speed would probably be something to do with your wheels or tyres... i'd also check the exhaust, as if the bike has been dropped in it's life that could be damaged and cause it to rattle Thumbs Up
Dunc
kawakid
PostPosted: 11:14 - 10 Jun 2009    Post subject: Reply with quote
If you don't know what your doing.
Find a good reputable mechanic and go and see him.
I've a twin and a 4.
Newbiker0507
PostPosted: 11:17 - 10 Jun 2009    Post subject: Reply with quote
im not paying
so id rather find out from here
Finglonga
PostPosted: 11:51 - 10 Jun 2009    Post subject: Reply with quote
Check the engine mounts, wheel balance, tyre condition, wheel bearings, does the CG have a balancer shaft?
Andy Sez....
F.Y.Y.F.F.
doggone
PostPosted: 12:47 - 10 Jun 2009    Post subject: Reply with quote
I'd look at the wheels urgently - balance weights missing?
Any sign of excessive play indicating wheel bearings about shot?
Creepin Moses
PostPosted: 08:37 - 11 Jun 2009    Post subject: Reply with quote
Check your steering bearings. Also check your handlebar brackets havent vorked even fractionaly loose. But it sounds bore like the above sugestions, Bearings in the front wheel
Bomb disposal expert, if you see me runnin, try to keep up.
Newbiker0507
PostPosted: 09:37 - 11 Jun 2009    Post subject: Reply with quote
I'm wary of taking it to a mechanics simply because they'll look at it, claim nothing is wrong and charge me £30 "to look at it".
Robbers
PostPosted: 11:47 - 11 Jun 2009    Post subject: Reply with quote
Robbers
Where abouts in the country are you? Maybe one of us lot could have a gander at it?
Newbiker0507
PostPosted: 12:19 - 11 Jun 2009    Post subject: Reply with quote
MarJay wrote:
Robbers
Edmonton, north London.
tutton
PostPosted: 19:37 - 11 Jun 2009    Post subject: Reply with quote
And thats why when you have big engine failure your going to be pretty fucked, or asking alot of favours and buying beer tokens, having a good trustworthy (yes they are out there) bike mechanic is a saint when you just cant be fooked to do a job Laughing
The last post was made 17 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 83.95 Kb
