gear engages when lever in, and clutches when out
MinhDinh
PostPosted: 16:32 - 10 Jun 2009    Post subject: gear engages when lever in, and clutches when out Reply with quote
rs 125 2005
Me and boss put new clutch plates, springs, friction plate and pressure plate together.
Any ideas?
We used the haynes manual and all seems correct according to them but obviously not lol.
The oil has been changed because we used something to thick.
Thanks
Hit the G spot. Wink
finpos
PostPosted: 18:18 - 10 Jun 2009    Post subject: Reply with quote
My guess would be that the clutch is operated by a cam on the inside of the clutch cover, and you've put it together with the cam in the wrong place. There's often some cunningly disguised index marks you need to line up.
f.
Fortuna
PostPosted: 20:28 - 10 Jun 2009    Post subject: Reply with quote
f.
I agree with that, it's probably upside down!
MinhDinh
PostPosted: 09:31 - 18 Jun 2009    Post subject: Reply with quote
Unfortunately not fixed. We had a look at it and it is built correctly. Any other ideas please? Thanks
PostPosted: 09:36 - 18 Jun 2009    Post subject: Reply with quote
It does sound like the release mechanism has been fitted backwards.
PostPosted: 10:18 - 18 Jun 2009    Post subject: Reply with quote
RS125 clutch works with a mechanism bolted to the inside of the clutch cover. This rotates on 3 ball bearings that go into holes that slope in gently from one side, so as the mechanism rotates the balls move on the slope and so move it in and out.
Only thing I can think of is that it has been put back in ~60 degrees out.
The last post was made 17 years, 152 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 48.6 Kb
