Tail light bulb keeps blowing out.
DKMonst3r
PostPosted: 21:36 - 10 Jun 2009    Post subject: Tail light bulb keeps blowing out. Reply with quote
Ive been having a small problem with mybike lately. Its blown 3 tail light bulbs now in the past 2 weeks. Not that its expensive but its better to correct the problem than leave it and ride with no lights at night and crash.
I use double winding bulb and one of the winding which is the tail light keeps going. The brake light still works. I suspect that might be caused by the vibration but im not sure. Whatcha think?
The bike is a Gilera Cougar 125.
finpos
PostPosted: 21:45 - 10 Jun 2009    Post subject: Reply with quote
Does the tail light (and head light...) only come on when the engine is running?
f.
DKMonst3r
PostPosted: 21:50 - 10 Jun 2009    Post subject: Reply with quote
f.
They work both ways engine on/off doesnt rlly matter. But now the bulb is gone so no tail light Neutral .
_sketch_
PostPosted: 08:32 - 11 Jun 2009    Post subject: Reply with quote
Make sure all the bolts holding the fairings on are secure - i had a problem not long ago when the rear mud guard was a bit loose and vibrating causing my bulbs to blow.
A sucker for 2 strokes
Cagiva Supermoto project
DKMonst3r
PostPosted: 18:31 - 11 Jun 2009    Post subject: Reply with quote
Ill buy a new one and ill tape the tail light so it doesnt move XD.
damz
PostPosted: 00:34 - 12 Jun 2009    Post subject: Reply with quote
also make sure you dont touch the glass part of the bulb as you leave a residue or something on the glass that can cause them to get too hot and blow out or something.
Current Bikes RVF400 - 94
Cars: RX7 FD, Eunos Roadster
steo
PostPosted: 03:11 - 12 Jun 2009    Post subject: Reply with quote
make sure the tail light bulb is the correct voltage & amperage for your bike. if the bulbs are the right ones then you have a short somewhere, check the connections inside the bulb holder & the wires going into the back of it. look for any exposed or worn insulation on the wiring where a live wire might be earthing.
truslack
PostPosted: 11:36 - 12 Jun 2009    Post subject: Reply with quote
That applies to halogen bulbs.
OP, get some bulbs from a different shop, my 500's blow some makes of bulb, but not others (very juddery bikes, cheap bulbs fail easily from the vibrations)
DKMonst3r
PostPosted: 00:59 - 14 Jun 2009    Post subject: Reply with quote
Cheers for all the replies guys Thumbs Up . Will have a look at it on monday and tell u what the problem is when i found out.
alun111
PostPosted: 01:09 - 14 Jun 2009    Post subject: Reply with quote
Could also be an intermittent wiring fault. Check all of the associated wiring for sections that are rubbed through and grounding on the frame/other wires.
baldy
PostPosted: 02:46 - 14 Jun 2009    Post subject: Reply with quote
Just buy a LED bulb, stick it in and never ever look at it or think about it again. Razz
Halfords do them in packs of 2 iirc.
There is a gap of 260 days between these two posts...
vcrmoss
PostPosted: 01:10 - 02 Mar 2010    Post subject: Reply with quote
...thats exactly what I did with mine and it really lets you forget to worry about it once and forever
The last post was made 16 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 70.41 Kb
