suzuki gsx600f no spark
chris924
PostPosted: 21:20 - 10 Jun 2009    Post subject: suzuki gsx600f no spark Reply with quote
hi there could u all help if u can bike was going fine was out 1 day and it cut off as if was out off petrol and its still not going there no spark i changed pluse gen eci well off a bandit but will looking for ecu only thing i not done is coils i checked wireing its ok the rev counter sits at 1.000 when its on pull plug from ecu rev go down same ass sidestand relay could u help
Ichy
PostPosted: 21:48 - 10 Jun 2009    Post subject: Reply with quote
Have you tried shorting out the sidestand switch and checked the killswitch?
chris924
PostPosted: 11:46 - 11 Jun 2009    Post subject: Reply with quote
i have mate still no luck
PostPosted: 11:54 - 11 Jun 2009    Post subject: Reply with quote
If a coil had gone then it would likely only affect 2 cylinders. Not that likely both coils would go at the same time.
Keth
chris924
PostPosted: 11:58 - 11 Jun 2009    Post subject: Reply with quote
its the only thing left i ordered a ecu and i got a bid on ebay for coils just put a new pluse gen side off engine still not so see what happens next
Ichy
PostPosted: 12:55 - 11 Jun 2009    Post subject: Reply with quote
Do the rest of the lights still work and does the bike turn over?
Just working through the list so have you checked the earth to the coils, power to the ecu, is there an alarm fitted?
chris924
PostPosted: 18:28 - 11 Jun 2009    Post subject: Reply with quote
checked the coils lights working engine turns over checked ecu plugs got a new ecu on order and i looking for coils
Ichy
PostPosted: 18:59 - 11 Jun 2009    Post subject: Reply with quote
If you have lost the spark to all four plugs then its unlikely that the coils have failed.
chris924
PostPosted: 19:43 - 02 Jul 2009    Post subject: Reply with quote
hi there i got the bike on the rd now was the ecu after all this time been on bike now 2 wks still running fine thks for all your help cheers !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The last post was made 17 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 59.47 Kb
