| lee8040 |
 lee8040 Nearly there...
| ms51ves3 |
 ms51ves3 Super Spammer
 Posted: 09:11 - 12 Jun 2009 Post subject: |
You have loads of options.
Find a proper fitting screw driver.
Use a punch to try and knock the screws around.
Dremel a slot into the screws and use a flat head screw driver to remove them.
Drill the head off the screws, remove the lid and then unscrew the stub with some pliers. |
| lee8040 |
| truslack |
 truslack World Chat Champion
| element |
 element World Chat Champion
 Posted: 11:03 - 12 Jun 2009 Post subject: |
first off dont use screwdrivers... waste of time.. get one of those little screwdriver bits you get for drills. find one that fits in perfect and give it a tap with a hammer into the bolt head.. it should fit in nice and snug. .. Then use a 6.5mm socket and a ratchet to turn the screwdriver bit while putting pressure down on the head.. You prob wont even need penetrating oil.. Ive done this loads and works every time.. ____________________ 04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME... |
| ZRX61 |
 ZRX61 Victor Meldrew
| Phoenix |
 Phoenix Twisted Firestarter
| puremagic72 |
 puremagic72 Brolly Dolly
 Posted: 06:56 - 13 Jun 2009 Post subject: |
I did the last one ms51ves3 stated just the other week.
The only way i could get it out.
Baz.  ____________________ Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids. |
| stirlinggaz |
 stirlinggaz World Chat Champion
| stinkwheel |
 Posted: 15:16 - 13 Jun 2009 Post subject: |
The trouble with those screws is that they are a water trap.
Rain water pools in the head of the screw and rots it. The ideal solution would be to fit socket head screws with those little domed plastic cover caps pressed into the heads.
I usually fill the head of the screw with a dab of grease after fitting them. A blob of silicone would achieve the same thing. Just pick it out before you want to remove it next time. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| seantobin43 |
 seantobin43 Nova Slayer
 Posted: 15:40 - 13 Jun 2009 Post subject: |
get the screwdriver and a hammer and hit the screwdriver with the hammer and try to turn the screw and also use a lot of WD40 or any other oil  ____________________ SEAN TOBIN  |
| _sketch_ |
 _sketch_ Scooby Slapper
| Mudskipper |
 Mudskipper World Chat Champion
 Posted: 14:07 - 15 Jun 2009 Post subject: |
I bought some cheapo (like 2 quid for a set) torx head bits for a screwdriver (like an allen key, but star shaped rather than hex) and hammered one in snugly. It 'bites' into the mashed up mess and comes out a treat.
Whatever you do, please make sure you replace the bolts with copperslipped new ones once you get them out! ____________________ CBR125|||GSXR400|||CBR400|||CBR400|||CB250RS|||GSXR750|||CB250RS
"You're clumsy, you eat too much and you behave like a 12 year old boy. But you know what? Every once in a while, you find a thumb." |
| Creepin Moses |
 Creepin Moses Nova Slayer
 Posted: 14:54 - 15 Jun 2009 Post subject: |
WD40 may help, but you could try boiling a kettle and pour the boiling water over the resovoir, then get an impact driver (with the right sized bit and give it some short sharp digs with a peace maker (hammer), this should start to loosen them up a bit. If that doesn't work last resort buzz the heads off with a dremmel tool or something, lift your lid off to let you grip the remainder with a pair of vice grips or mole grips. But keep plying with WD40 from time to time.
 ____________________ Bomb disposal expert, if you see me runnin, try to keep up. |
The last post was made 16 years, 242 days ago. Instead of replying here, would creating a new thread be more useful? |
