HDD space constantly changing
K0rnIsAFAGGOT This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
DEN MONKEY
PostPosted: 15:03 - 12 Jun 2009    Post subject: Reply with quote
Virtual memory maybe ?
meh
Phoenix
Twisted Firestarter
PostPosted: 16:24 - 12 Jun 2009    Post subject: Reply with quote
It's your swap file changing size, which as mentioned above controls how much virtual memory you have (hard drive space reserved for storing random data that's beeing used by running software).
When you deleted 5gb of stuff your swap file probably increased in size to take up a lot of that new free space you created as it was no doubt too small to start with. They're rarely more than a couple of gb in size though, depends what you run. You should always have a few gb free to allow the swap file space to work in.
el_oso
PostPosted: 19:58 - 12 Jun 2009    Post subject: Reply with quote
do you have defragmentation tool scheduled.
the defrag tool uses HDD space when it is organising your files. and then deletes them once it is done
ncrn
PostPosted: 09:12 - 13 Jun 2009    Post subject: Reply with quote
If it is vista, click the windows button and type disk cleanup, that should help you to grab some disk space back, you will probably have a ton of cookies on your pc you could get rid of.
tofu-wtf
PostPosted: 15:17 - 13 Jun 2009    Post subject: Reply with quote
It will almost deffinately be the swap file (virtual memory). You can fix the size of this file but if you only have 581MB of free disc space and you are running Vista you need to take action NOW!!
You need more disc space for your OS and without knowing how your system is set up it isn't easy to advise a next 'cost effective' step. Find someone that knows what they're doing (not the bloke that offers to format your system when you get a virus) and get them to have a look.
(you could search for all files and folders created or modified within the last week or so, that will show if an application is creating files)
Eagles may soar.............but rats don't get sucked through jet engines!!
1999 ZX6r G1.....it makes me smile Very Happy
The last post was made 17 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 49.15 Kb
