Something strange just happened.
MementoMori
PostPosted: 20:12 - 12 Jun 2009    Post subject: Something strange just happened. Reply with quote
Basically, my bike fixed itself.
I was just out on an evening thrash round some local twisties. Now my front brakes have been dodgy for a long time now but I've not been able to sort them out because the money has gone on other things. They're spongy as hell, next to no stopping power, the lever comes in to within about a centimetre of the throttle, and one of my discs is warped. Yes, they're dangerous.
I tend not to rely too heavily on brakes, using the engine as one in the main, so I've lived without it for a while and the simple 5 mile commute to work down the A5 does not require substantial use. Recently I've been feeling the itch for a good fast ride so I've been out a few times today for a hoon. Obviously giving it the beans requires setting up the bike before corners and getting your braking done etc, so I set up for this last corner, braked, and powered through. Then I entered a 40 then 30 so just cruised for a bit. So when it came to using my front brakes, I found a profound difference.
The lever requires a bit more of a stretch to get to and the braking power begins instantly upon application, unlike before where it would start about half way in. When applied, the lever only comes to within about an inch of the throttle now. I think the braking power is about the same but to be honest I was being cautious of it as I headed back to the house. I am going to pop back out now just for a quick run to test for sure if the brakes are working OK as they are now.
But in the meantime, does anybody know WTF might have happened?
Confused
The tiger who came for a pint
Flip
PostPosted: 20:18 - 12 Jun 2009    Post subject: Reply with quote
Confused Air in your brake lines?? Confused
Why are you riding with dodgy brakes? Easy to bleed and replace the fluid and pads.
A bottle of fluid is only around £4.
That_Hornet
PostPosted: 20:19 - 12 Jun 2009    Post subject: Reply with quote
a bike that fixes itself!!! Shocked
No more garage fees! no more hours in the garage slaving away!
I want one Thumbs Up
MementoMori
PostPosted: 20:39 - 12 Jun 2009    Post subject: Reply with quote
Because I need to replace the discs aswell which for genuine Kwak ones are 200 quid. I'm not buying EBC, these came with the bike and they're shite. I don't really want to do half a job and do a bit here and a bit there, changing the pads without changing the discs etc, the plan was to overhaul the brakes all in one. My entire braking system is fucked. I need new pistons and gaskets aswell. This month I've been doing a massive stint at work and haven't had the time to do anything about this. But it's my only form of transport.
I've just been round the estate a few times and to the distaste of my fellow residents, I have concluded that the stopping power of the brakes is significantly improved. Now this is either a miracle or dodgy as fuck. I'm guessing the second.
Flip
PostPosted: 21:10 - 12 Jun 2009    Post subject: Reply with quote
I'd spend the £4 on fluid for now. Maybe that'll keep the lever acting as it should. Unless of course it's a problem with the master cylinder? Thumbs Up But £4 is neither here nor there is it. Smile
yuri2085
PostPosted: 21:48 - 12 Jun 2009    Post subject: Reply with quote
I was thinking the same as flip, why arent you dead.
But on the other hand congratulations on self bleeding brakes!
Epic 'taters
PostPosted: 22:54 - 12 Jun 2009    Post subject: Reply with quote
A miracle! Praise Jesus!
Or it could have been homeopathy.
Or something.
Suzuki Burgman 400. BMW R1100R
"I must warn you that I do not positively assert that anything I say is wholly as I say it is. I merely report... how each thing appears to me at the moment." - Sextus Empiricus
billyboy
PostPosted: 23:22 - 12 Jun 2009    Post subject: Reply with quote
my old hack as a doggy front brake some days lever comes back to the bars and other days its shit hot suspect m/c
2Hondas
PostPosted: 23:54 - 12 Jun 2009    Post subject: Reply with quote
I wouldn't want to be there when it un-fixes itself, inevitably when you really need it to work.
Current - 2010 Kawasaki ER-6n - Green
Previous - 2000 Honda CB600F Hornet - Yellow
Previous - 2007 Yamaha YBR125 -Blue
MementoMori
PostPosted: 08:30 - 13 Jun 2009    Post subject: Reply with quote
It's off the road now anyway. It broke down last night in the ASDA car park. I need a new battery. Thankfully this is my weekend off so I can get that sorted hopefully in time for Monday. If not I'll have to take my partner's ZX7R. It's a tough life sometimes but I'm sure I'll cope!
PostPosted: 14:08 - 13 Jun 2009    Post subject: Reply with quote
Possibly the heat generated by the more enthusiastic riding caused the caliper to free up a bit, it's now moved closer to the disc, meaning the piston doesn't have to move as far.
Or boiling the brake fluid has invigorated the magic brake line pixies, who were fat and lazy having only a 5 mile commute to contend with.
PostPosted: 16:07 - 13 Jun 2009    Post subject: Reply with quote
I got some discs off this place: https://www.sandybikespares.co.uk/
Seem decent enough quality and WAY cheaper than anything else I've seen.
PostPosted: 18:31 - 13 Jun 2009    Post subject: Reply with quote
I asked about the brand they did on here before and it seems they've had a lot of bad press for a lot of reasons, so I avoided them.
PostPosted: 18:44 - 13 Jun 2009    Post subject: Reply with quote
Fair dos. The ones I've had have all been solid discs, maybe the floating ones aren't as good?
PostPosted: 19:18 - 13 Jun 2009    Post subject: Reply with quote
Think it was floating ones people were commenting on; be interesting to see how they are in a year's time.
Though, as ever, even ten good reviews to one bad is a pretty bad ratio, so I'm going to remain sceptical for the moment... though, may end up getting some anyway for the 9 to pass the MOT cheaply Confused.
The last post was made 17 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 85.67 Kb
