| DrSmith |
 DrSmith Two Stroke Sniffer
| steo |
 steo Nova Slayer
| garyd |
 garyd Brolly Dolly
| wizzzard |
 wizzzard World Chat Champion
 Posted: 08:39 - 13 Jun 2009 Post subject: |
My first thought would be a bent or broken valve. I had exactly the same symptoms on my little sr and it had bent the inlet valve and snapped it right it the top of the valve stem. My son was riding it at the time and he was giving it more than he should have been as well.
Not a difficult job to put right if it hasnt knackered your guide up although i couldnt say why it had done it in the first place other than general wear.
Good luck  ____________________ And did you exchange a walk on part in the war for a lead role in a cage?
Zeitgeist / Addendum / Moving forward |
| DrSmith |
 Posted: 19:43 - 13 Jun 2009 Post subject: |
The wear you're describing happens over time not instantly. Hard to diagnose from your description. Could be the conrod let go? You can check for a busted rod by pulling the sparkplug and putting a pencil down the hole until it touches the piston. Now turn the engine a bit by hand - if the pencil doesn't move you've rodded the motor.
What does the oil look like? ____________________ a.k.a 'Geri'
| DrSmith |
 Posted: 20:11 - 13 Jun 2009 Post subject: |
Hmm, well if the piston's moving and the valves are in place and the cam's turning then you've either popped the piston, twatted a valve, or blown a gasket. Your description of some of the symptoms still doesn't help diagnosis. Does the bike have a de-compressor? ____________________ a.k.a 'Geri'
| garyd |
 garyd Brolly Dolly
| DrSmith |
| bikersupermot... |
 bikersupermot... Could Be A Chat Bot
| bikersupermot... |
| DrSmith |
| dan3411 |
 dan3411 Renault 5 Driver
| bikersupermot... |
| DrSmith |
 Posted: 19:30 - 14 Jun 2009 Post subject: |
 Posted: 20:21 - 14 Jun 2009 Post subject: |
Piston is well-popped  ____________________ a.k.a 'Geri'
| DrSmith |
| garyd |
 garyd Brolly Dolly
 Posted: 06:01 - 15 Jun 2009 Post subject: |
Sorry Dr my bad,thought it was you i sent the number to  ____________________ CRF230 all you need |
| steo |
 steo Nova Slayer
| DrSmith |
| steo |
 steo Nova Slayer
| DrSmith |
| steo |
 steo Nova Slayer
| DrSmith |
The last post was made 17 years, 114 days ago. Instead of replying here, would creating a new thread be more useful? |
