1st scrambler and a couple of noob questions
jimmer
PostPosted: 18:01 - 11 Jun 2009    Post subject: 1st scrambler and a couple of noob questions Reply with quote
hi guys and girls,i just got my first scrambler and have a couple of questions. oh its a honda mtx125 water cooled.
how do i check the gearbox oil level and what mixture of 2 stroke too petrol is best? for instance i put 4 litres of petrol in a jerry can and bought 1 litre of 2 stroke oil how much oil do i put into the jerry can a guy told me to put in 150ml of oil in but can you guys confirm,thanks in advance
Beamexican
PostPosted: 20:05 - 11 Jun 2009    Post subject: Reply with quote
Hi mate,
To check the gearbox oil there is a level screw on the right hand side engine casings its above the brake lever and is either an 8mm or 10mm nut.
You're supposed to undo it and see how fast the flow of the oil is, the oil should trickle out not pour everywhere and if there's no flow then theres not enogh in there, not the most accurate way too check really. if you don't know when it was last changed i'd say just drain it and replace.
Always ran mine on light gear oil, think it's 500ml but ill check in my manual if you need.
I run my mtx at 33:1 on premix which is 150ml of oil to 5 litres of petrol.
Hope this helps.
Rick
jimmer
PostPosted: 15:56 - 14 Jun 2009    Post subject: Reply with quote
cheers for the reply,what kind of gear oil do i ask for?and i think its restricted as it seems a bit slow,is there any way of checking?
stirlinggaz
PostPosted: 00:31 - 15 Jun 2009    Post subject: Reply with quote
hi,
why are you running it pre-mix?
doesnt it have the oil pump fitted? (has someone removed it?)
look under the left cover for oil tank.
remove engine casing to check oil pump. (you should be able to see the oil pump control cable disapear into a hole on the engine casing)
cheers,
GAZ
welshlad25
PostPosted: 12:19 - 17 Jun 2009    Post subject: Reply with quote
u dnt mix it m8 under the seat theres a bottle ur 2 stroke goes in there .
The last post was made 17 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 42.68 Kb
