GPZ500 starting problems again!
c00mes
PostPosted: 10:08 - 15 Jun 2009    Post subject: GPZ500 starting problems again! Reply with quote
Hi i have been having a lot of problems with my gpz, it will turn over and actually fire but wont stay started, then if you try again it backfires and is kicking out white smoke, could the carb be running to lean? if so how do i adjust it?? and if its not not what could it be, it has new plugs,oil and filter and the carb has been cleaned?
cheers
Neil
PostPosted: 10:34 - 15 Jun 2009    Post subject: Reply with quote
When you say it won't stay started, do you mean if dies when you try and rev it? If so that sounds like what Charlottes GPZ500 used to do as it got water into the petrol tank, which then went into the carb when you switched to reserve. As such drain the carbs, make sure the petrol is not on reserve and try again (and when you get a chance drain the tank and get rid of the water in it).
c00mes
PostPosted: 10:43 - 15 Jun 2009    Post subject: Reply with quote
hi
i dont have the tank on it at the moment it is running from a jerry can as i am stripping it down, yes it sounded like it was going to run and rev'ed up then died?
PostPosted: 10:47 - 15 Jun 2009    Post subject: Reply with quote
Err, have you blocked off the vacuum line to the fuel tap? If not then it will be getting a load of air in after one of the carbs.
c00mes
PostPosted: 11:00 - 15 Jun 2009    Post subject: Reply with quote
just went and made sure it was done, it isn't firing now and the battery has run down i will try again when the battery is charged,
thanks for your help
Neil
yambabe
PostPosted: 21:51 - 16 Jun 2009    Post subject: Reply with quote
I have asked He Who Knows About This Stuff cos when you said "white smoke" I immediately thought you might have some diesel in your fuel somewhere.
However he says no, and he wants to know have you had the plug leads off cos it sounds like you might have them on the wrong way around. Worth a try?
The last post was made 16 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 48.58 Kb
