Newbie (on the site) with a engine problem.
bkf_uk
PostPosted: 22:52 - 15 Jun 2009    Post subject: Newbie (on the site) with a engine problem. Reply with quote
Hello all first post and wonder if you can help.
I Recently bought a poorly suzuki gn250 that had a neglected top end.
Have had a number of project bike over the past 6 years and am happy to rebuild a engine.
Fully stripped and re-built the top end, having found a destroyed valve guide and bent valve, all new guides and gaskets all round.
When i first started the engine after rebuild as expected a giant white cloud of choking smoke poured from the exhausts and then finally cleared. however have let the engine sit for a day or two and again it starts with a choking thick white cloud (oil been burnt).
Sick
My question is where the hell is the oil coming from? it's been fully rebuilt!
Brick Wall
Any ideas are most welcome!
Bryan
Ariel Badger
PostPosted: 22:58 - 15 Jun 2009    Post subject: Reply with quote
It can only come from two places, past the rings or down the guides. As it is a start up problem I say check the guides and any seals. How does the plug look?
bkf_uk
PostPosted: 23:01 - 15 Jun 2009    Post subject: Reply with quote
plug is new but showing signs of a nice brown colour, the guides and seals are brand new, they where replaced after finding one was shattered.
Ariel Badger
PostPosted: 23:08 - 15 Jun 2009    Post subject: Reply with quote
If you are certain that the top end is ok it must be the bore or rings.
bkf_uk
PostPosted: 23:15 - 15 Jun 2009    Post subject: Reply with quote
i think ill give the old trick of an "italian Tune up" a shot first before ripping the infernal thing apart again. Although the engine looks like it was rebored not too long ago, but the bike has got 70k miles on it!
steo
PostPosted: 02:47 - 16 Jun 2009    Post subject: Reply with quote
if the engine needed a rebuild after you bought it then there's a good chance that your exhaust is clogged up with burnt waste oil from then old engine thus giving you the impression that there's a problem with your new rebuild. as the gn have a sealed exhaust you cannot take the baffle out to clean it. before you consider taking the engine apart, do a compression test or if you can get hold of another exhaust, try that.
iooi
PostPosted: 13:13 - 16 Jun 2009    Post subject: Re: Newbie (on the site) with a engine problem. Reply with quote
Sick
Brick Wall
Bryan
Oil being burnt is usually blue smoke. White would tend to indicate a build up of condensation being burnt off.
Is the drain hole clear in the exhaust ?
I take it when you replaced the valve and guides, you lapped the valve to its seat.
bkf_uk
PostPosted: 23:29 - 16 Jun 2009    Post subject: Reply with quote
valves where lapped in to the head by the company i had fit the guides. The exhaust was also replaced and is brand new, therefore it shouldnt have any oil inside at all. Started the bike again today and it was much cleaner, but still a bit of white smoke.
The oil and filter are new, as are most components with the bike. it's had a full stirp down and rebuild.
Could a bad batch of petrol cause this? the only reason i ask is i used the same petrol in my lawnmower (standard 95ron unleaded from a supermarket) and it was running lumpy as hell, in fact come to think of it, filled the car up at the same time and it isnt running right either?
steo
PostPosted: 23:37 - 16 Jun 2009    Post subject: Reply with quote
this is going to sound like a silly question but did you happen to put diesel into your fuel tank or use it in anyway shape or form for cleaning or use a similar product?
bkf_uk
PostPosted: 00:03 - 17 Jun 2009    Post subject: Reply with quote
No diesel, petrol was straight from the pump. but am starting to wonder if it was contaminated. cant get the car to idle properly.
Will get some fresh petrol from a different source and flush the tank out to see if it makes any difference.
The last post was made 16 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.59 - MySQL Queries: 13 - Page Size: 63.48 Kb
