BMW R100 Carb balancing
tatters
Exxon Valdez
PostPosted: 17:45 - 16 Jun 2009    Post subject: BMW R100 Carb balancing Reply with quote
Bit of a rare one me asking for help Laughing
But......have any of you lot got any experience balancing carbs on Air cooled BMW,s or a vacuum gauges that l can borrow as my Carbtune II does,nt seem to like the stock CV bing carbs on my BMW.
located in surrey and really need to get this sorted by next Tuesday. Thumbs Up
temeluchus
PostPosted: 19:39 - 16 Jun 2009    Post subject: Reply with quote
One method is to put alot of slack in the throttle cables and then take out one sparkplugs. Then adjust the bike to idle on one cylinder. Then swap plugs and set it to idle with the other cylinder.
Then with both you will get a high idle, you adjust the idle down with equal turns on the idle speed screw. THEN adjust the slack in the throttle cables to be equal.
That should get things fairly well adjusted.
temeluchus
PostPosted: 19:42 - 16 Jun 2009    Post subject: Reply with quote
oh an make sure you earth your sparkplugs when they are out-if you have an electronic ignition unit, it wont like having ungrounded sparkies!
tatters
Exxon Valdez
PostPosted: 19:43 - 16 Jun 2009    Post subject: Reply with quote
Cant do it that way on the later CDI/hall sensor engines as it can fry the CDI, found a specialist near me hopefully he can help.
temeluchus
PostPosted: 20:01 - 16 Jun 2009    Post subject: Reply with quote
its fine as log as you earth the sparplug.
Get a length of wire and bare 2 inches off one end. Wrap this around the threads on the sparkplug. Bare the other end and attach it to earth-screw it down on the frame or motor somewhere. That will prevent the igniton being damaged.
The last post was made 16 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 44.65 Kb
