Fully synthetic in my 600 monster?
garth
PostPosted: 18:00 - 15 Jun 2009    Post subject: Fully synthetic in my 600 monster? Reply with quote
Just filled my monster up with fully synth, some people that race them say it's ok, some say not. Bit late now as I've already done it, but..
Will this be ok? I've ridden it up the road and it doesn't seem to slip, but it's not at full temp. It's a 583 so wet clutch.
Elp! Embarassed
steo
PostPosted: 04:10 - 16 Jun 2009    Post subject: Reply with quote
fully synth oil is used in high revving sports machines which generate extreme engine temperatures & if you were racing the duke then that's what you would want in your engine. you shouldn't notice any difference in your engine & hav'nt heard of any problems with clutch slip. your better off just sticking to the manufacturer's spec & use the oil they recommend.
PostPosted: 08:06 - 16 Jun 2009    Post subject: Reply with quote
Personally I'd just use whatever the manufacturer recommends and change it regularly.
May as well just see if it slips now though, seems like a waste of perfectly good oil otherwise. Chances are it'll be ok. Ran fully synth in my hornet and that was ok.(It was all they had at the shop).
garth
PostPosted: 08:52 - 16 Jun 2009    Post subject: Reply with quote
Hmm, yeah.
Problem is I won't be using it until race day. I suppose if I just take semi synth with me, and if it slips, dump it out and change it after qually?
Hassle I don;t really want...
PostPosted: 08:53 - 16 Jun 2009    Post subject: Reply with quote
Get it up to temp somehow then, even if it is just wazzing it up and down the street for half an hour. At least then you'll know.
PostPosted: 09:38 - 16 Jun 2009    Post subject: Reply with quote
Shouldn't really make much difference. Fully synthetic oils main advantage is that they need less additives to maintain a half decent viscosity range, and as it is these additives that wear out the fully synthetic oils last longer.
sickpup
Old Timer
PostPosted: 21:30 - 16 Jun 2009    Post subject: Reply with quote
Seem to remember AGIP Synthetic was recommended back when I worked on them.
djr
PostPosted: 21:50 - 16 Jun 2009    Post subject: Reply with quote
Isn't it only the clutch that's majorly affected by the oil you use? and arent monsters all dry clutch *-) ?
PostPosted: 08:21 - 17 Jun 2009    Post subject: Reply with quote
No, see OP.
Only some of the versions that use the 916/955/996 engine are. Wink
garth
PostPosted: 08:33 - 17 Jun 2009    Post subject: Reply with quote
The 6 and the 750 are wet clutches. The 9 isn't.
I've bought semi synthetic too now. I'll have another blat later today and see if it slips, if not I'll do my 1st qually session and see how it goes. It's a healthy clutch anyway - I've fitted new plates and springs, and after all the engine is only kicking out ~50bhp.
I have read elsewhere that AGIP F/S is fine in them too. What's in a brand?
Jubal
PostPosted: 18:03 - 17 Jun 2009    Post subject: Reply with quote
You should have no problem with bike specific F/S oils as they are formulated to cope with wet clutches. Problems arise when car oil is used as they contain Friction Modifiers and it's those additives apparently which mess the clutch up.
PostPosted: 20:41 - 17 Jun 2009    Post subject: Reply with quote
Can do, but not always. I have used fully synthetic car oil in bikes without clutch issues.
The last post was made 16 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.48 - MySQL Queries: 15 - Page Size: 73.29 Kb
