| dextersaurus |
 dextersaurus World Chat Champion
| Mark65 |
 Mark65 World Chat Champion
| baldy |
 baldy World Chat Champion
| dextersaurus |
| Ant132 |
 Ant132 World Chat Champion
 Posted: 20:08 - 16 Jun 2009 Post subject: |
By the look of it the rocker cover seems to be the worst part of it. Check its not leaking down the and resting on the crankcase before you decide its the base gasket too.
The base gasket is an easy fix and if it drinking oil then there is your oppurtunity for a bit of a top-end overhaul. There still seems to be oil on the dipstick so just make sure you are testing it fairly by wiping off all the excess oil and then resting disptick in and not screwing it in (might be the opposit though and thats why you are not getting a reading, im not sure of how it is on the CG)
Gear level seal is probably worn aswell, again an easy fix.  ____________________ 1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200 |
| Nipedley |
 Nipedley Scooby Slapper
 Posted: 20:54 - 16 Jun 2009 Post subject: |
I have a CG too, when I saw the oil around the gear lever and underneath I too thought I had an oil leak but when you take off the front sprocket cover it's fairly obvious its all just getting flung off from there, I wouldn't worry about that too much
As the other have said it looks like you have a gasket leak up top and it's leaked down around your clutch, I'm not sure how likely it is for two gaskets to have failed at once? Maybe they have but either way I don't think it's a replacement engine job just yet  |
| dextersaurus |
 Posted: 21:04 - 16 Jun 2009 Post subject: |
| Nipedley |
 Posted: 21:10 - 16 Jun 2009 Post subject: |
That does sound pretty neglected, poor CG As for the electric start, I don't blame you Mine is an electric start, I much prefer to just press the starter button than mess around with a kickstart! |
| dextersaurus |
| Nipedley |
 Posted: 21:24 - 16 Jun 2009 Post subject: |
Mine's the newer style on an 05 plate, I was lucky though as it had been in storage for years and I got it fairly cheap So I've been able to look after it, I do think the CG are a great bike for what they're made for. Glad to see you're going to do yours up
It must be a nice feeling to ride knowing that some of your own blood sweat and tears is helping that engine chug along! Go for it  |
| dextersaurus |
 Posted: 21:29 - 16 Jun 2009 Post subject: |
| Creepin Moses |
 Creepin Moses Nova Slayer
 Posted: 22:40 - 16 Jun 2009 Post subject: |
You can get full gasket sets for the cg's very cheaply now that should cover all the seals you need, yeh too much tension on the chain can cause probs with the drive, it puts extra strain on the drive shaft etc, I agree leave a little bit of free play in the chain.
 ____________________ Bomb disposal expert, if you see me runnin, try to keep up. |
The last post was made 16 years, 232 days ago. Instead of replying here, would creating a new thread be more useful? |
