Using quick shift...is it a bad thing on a honda 125cc ??
freakymadness
PostPosted: 15:12 - 17 Jun 2009    Post subject: Using quick shift...is it a bad thing on a honda 125cc ?? Reply with quote
Just a quick one!! Laughing ...mind the pun there!! Rolling Eyes ...any way i just wanted to no if using the quick shift method on my gilera cougar ( honda engine 125cc )...would damage the engine etc?
the only reason i ask is because it is a big heavy bike and when i pull out from roundabouts every second counts as you all no...especially on a cruiser with a small engine...so what is your opinion all???
BIG ANT out!!! Karma
cammy mack
PostPosted: 15:25 - 17 Jun 2009    Post subject: Reply with quote
binning the clutch is ok going up the gears mate, wouldn't advise it going down them though Thumbs Up
freakymadness
PostPosted: 19:43 - 17 Jun 2009    Post subject: Reply with quote
.....so out of intrest why is it ok to bin the clutch to go up the gears but not down???? cheers buddy!!!
The Artist
PostPosted: 20:25 - 17 Jun 2009    Post subject: Reply with quote
Because the gearbox is designed that way. It is sequential going from 1st to whatever your top gear is, not the other way round.
DKMonst3r
PostPosted: 01:21 - 18 Jun 2009    Post subject: Reply with quote
Lol sounds to me like u need to practice ur pulling away skills. I have the same bike and it does go nicely u just need to rev it a bit Razz. And to answer ur question no its not a bad thing if done right Smile .
freakymadness
PostPosted: 04:09 - 18 Jun 2009    Post subject: Reply with quote
Well as a learner yes i agree i need more practice Wink hence being a " learner " i live in a busy city and some junctions can be a bit scary so the quick shift is handy...oh and i pull away just fine thanks!! Laughing
PostPosted: 05:26 - 18 Jun 2009    Post subject: Reply with quote
Gearbox is sequential in both directions. What I think you meant to say was that when going up the gears the revs drop with each change, and since you have to shut the throttle to unload the gearbox the revs drop doing that too so the two combine naturally.
When changing down the revs are higher in each next gear down, so shutting the throttle to unload the box works against the need for higher revs in the lower gear you are trying to select.
On some bikes clutchless downshifts works wonderfully well, maily lower-powered bikes with non-undercut gearboxes. Others you have to develop a knack to make them consistently smooth.
DaveH
PostPosted: 05:33 - 18 Jun 2009    Post subject: Reply with quote
No they are not Rolling Eyes
Most bikes have straight cut gears, which means that they mesh together quite easily and be happy as going clutchless in either direction, in fact I would argue that a well timed down shift stresses the gears less than a well timed up shift as upshifts are under power.
Its all down to technique in the end.
https://www.timhastingsracing.co.uk/
ZX7R & ER6F
Acemastr
PostPosted: 07:43 - 18 Jun 2009    Post subject: Re: Using quick shift...is it a bad thing on a honda 125cc ? Reply with quote
So all in all, yes.. you can (i do, just not 1st to 2nd) and yes it will get you going slightly quicker but not by a whole lot. I very much doubt you'd get the front end up on a hard take off so i'd recommend lots more revs, that'll get you going quicker. clutchless downshifts just aren't worth it in my opinion, plus the quick blip sounds sexy Smile
2016 Toyota Tacoma Limited
freakymadness
PostPosted: 16:50 - 18 Jun 2009    Post subject: Re: Using quick shift...is it a bad thing on a honda 125cc ? Reply with quote
You would need a fork lift to get the front end up on my bike lol.....as im new to bikeing and still getting used to my bike the reason i asked is because it seems a lot smoother and quicker with the quick shift but i still use the clutch every where else as it is a cruiser bike not a race bike...i look forward to passing my test so i don't have this power problem Thumbs Up
The last post was made 17 years, 152 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 69.14 Kb
