Strange things happening.........
nomoregt4
PostPosted: 23:24 - 17 Jun 2009    Post subject: Strange things happening......... Reply with quote
Evening folks. Got a slight wee problem with my CBR 600F. The post may be a bit long as I tend to waffle on Laughing Rolling Eyes
Coming home from work on Sat, bike started up fine & rode perfectly back home until I got 1/2 mile from my front door, slowing down for a roundabout, the bike started to run really rough & eventually cut out.
As she was coming to a slow stop, I tried twisting the throttle, but nothing happened. I pushed it into the layby & walked back home.
After around an hour, I went back to my bike with jump leads at the ready, but thought I'll try & start it without the leads first, just in case she fires up, & she did Confused Very Happy .
Now yesterday I went into town, did a few bits & on my way back, she started to run really roughly, almost 'kangarooing' as I'm riding along & again came to a slow stop & cut out.
This all happened at low speeds by the way (under 30 mph).
I tried to start her again, but all I heard was a very fast clicking noise, which I have now located just infront of the battery housing. (I forget the name of the part Embarassed )
I waited around an hour for my g/f to come rescue me with a tool box & jump leads. I jump started the bike & thought excellent, I'll get it home at least Rolling Eyes .
Got about a mile down the road & she started running really rough again. I managed to crawl the 4 ish miles home at 20 mph running again really roughly.
Now my first thoughts was the battery. I've since trickle charged it for 12 hours, tried it today & she started up fine.
But if it was a low battery charge, this wouldn't cause the sudden rough & lumpy running, would it? I thought the battery was initially there just to start the bike & obviously run the electricts after starting.
My brother mentioned it could be the alternator packing up.
The bike is a 1991 with 17k miles on the clock.
Shes been an angel until now Evil or Very Mad
Any help or suggestions would be a great help. Even better would be a helping hand this weekend Wink Thumbs Up . I'm based in West Sussex, near Haywards Heath. I make a nice cuppa...... Laughing
Rich
The Artist
PostPosted: 23:34 - 17 Jun 2009    Post subject: Reply with quote
I know nothing of your bike but by the sound of it I would say an electrical fault. Possible the coils as they heat up becoming a bit intermittent.
Check them for visible damage. That is if you have coils!
finpos
PostPosted: 00:06 - 18 Jun 2009    Post subject: Reply with quote
Those CBRs are notorious for having wonky ignition when the battery is weak, usually they just won't start despite the engine turning over at some clip. If I'm not wrong the battery has to run both the ignition and a fuel pump.
So you may well have a tired battery. If it's a few years old then almost certainly so. You should also check that the battery is charging when the bike is running (look for approx. 14V across the battery terminals). If it's not charging, then more likely a fault with the reg/rec or wiring than with the alternator.
f.
steo
PostPosted: 00:26 - 18 Jun 2009    Post subject: Reply with quote
i would agree with finpos, i'd say your reg/rec or generating coils are fcuked but most likely rec/reg. the bike is running off the battery to generate the power for the engine & as soon as the battery starts to go flat, the bike begins to run crap. when you leave the bike for a while the battery replenishes itself to a certain extent to give the impression that all is well again but a few miles down the road & your back to square one. post a reply if you have trouble finding the reg/rec, plenty of david baileys on here will post a pic of the part.
Villers
PostPosted: 13:02 - 18 Jun 2009    Post subject: Reply with quote
As above but you can check it by opening the fuel tank once it conks out and if its under a vacuum you will hear it sucking air in.
My moneys on poor battery performance though Wink
Rockhopper This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
yuri2085
PostPosted: 14:42 - 18 Jun 2009    Post subject: Reply with quote
Check the battery terminals perhaps? took me ages to check that and it turns out thats what was causing me a lot of probably very similar to yours.
Meaning check they're screwed in nice and tight with good surface for conduction.
Timmeh
PostPosted: 14:52 - 18 Jun 2009    Post subject: Reply with quote
Another one for the reg/rec.
Get a voltmeter and check the battery voltage with engine at idle, and then at 6-7000 rpm, and blip it to 9k.
12-13v at idle
13-14v at 6k
14.5-15.5v at 9k
Anything less than 14v at 9k and it's prolly had it.
Dezeaz
PostPosted: 17:44 - 18 Jun 2009    Post subject: Reply with quote
Could be a number of things!
I had the same symptoms around this time last year. Bike would kangaroo and cut out sometimes. Checked almost everything on the bike that people suggested on the forums and stil couldnt find the problem.
I checked the FI error codes by shorting 2 terminals in the ECU which was giving an error for the crank position sensor.
Booked it in to a garage who found out it was a problem with the ignition coil pickup sensor.
veze
PostPosted: 17:59 - 18 Jun 2009    Post subject: Reply with quote
just a thought, maybe a ht lead or ignition coils could be breaking down under tension? id deffo check the battery first though.
tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300
Bofh5
PostPosted: 08:56 - 19 Jun 2009    Post subject: Reply with quote
Its either fuel starvation or electrics which on the CBR is going to be the reg/rec if mine was anything to go by.
the standard reg is a bit pants and prone to overheating. this will be visible by a melted plastic on the connector block.
there is a really good guide to checking all the various voltages on here somewhere if you do a search.
(L)users...Disk space is to good for them.
Bikes: Honda 50 / CB125-TDC / 93 CBR600 F2 (Stolen & Trashed) / 2001 SP-1 (Sold) / 95 CBR600 F3
Timmeh
PostPosted: 11:09 - 19 Jun 2009    Post subject: Reply with quote
Just to add what bofh said you can easily get replacement reg/recs for these bikes on eBay or david silver, but buy one with the metal heatsink bolted to it as the crappy plastic ones do have a habit of melting.
Bofh5
PostPosted: 12:03 - 19 Jun 2009    Post subject: Reply with quote
The one i bought was from germany and had a decent size heat sink on and so far no problems with it.
nomoregt4
PostPosted: 17:50 - 19 Jun 2009    Post subject: Reply with quote
Wow, cheers for all the replies guys. I'm overwhelmed Shocked
Err, where abouts is the reg/rec located Embarassed I have since charged the battery & started her the other day, but didn't actually go out for a spin. What is reg/rec short for Embarassed
I'll get my ass down to Halfords or look on Ebay for a voltmeter & do the suggested tests on the battery.
Again, thanks for all your help, I really appreciate it.
Thumbs Up to you all Cool & a virtual beer/larger on me Cool
Richard
steo
PostPosted: 18:06 - 19 Jun 2009    Post subject: Reply with quote
reg/rec is just short for the regulator & rectifier which is a small alloy box, a bit bigger than a cigarette box with fins on it. it connects into your wiring loom via a junction box connector. it's usually situated near the battery so you'll probably have to take the side casings off to find it. one of the guys will post a picture of what you should be looking for.
veze
PostPosted: 18:26 - 19 Jun 2009    Post subject: Reply with quote
if its anything like my cbr400, and all the other bikes that ive owned, it will either be behind the left or right rear fairing panel bolted to the subframe. you looking for a small box, like stated before, about the size of a 20 block of fags. it will either be a smooth plastik bock or will have finns in it because of the heat.
Bofh5
PostPosted: 18:36 - 19 Jun 2009    Post subject: Reply with quote
its on the right hand side about half way along the seat and has a plastic connector block plugged into it.
nomoregt4
PostPosted: 11:05 - 21 Jun 2009    Post subject: Reply with quote
Nice one, cheers folks. I'll have a look today Cool
Rich
nomoregt4
PostPosted: 15:20 - 21 Jun 2009    Post subject: Reply with quote
Found a voltmeter like this on Ebay. Will this suffice?
https://www.sourcingmap.com/three-and-half-bits-lcd-digital-multimeter-voltmeter-a830l-p-16365.html?currency=GBP
If The battery was low on power & I've since charged it up, would I still need to replace the Reg/Rec box?
Cheers,
Rich
Serendipity
PostPosted: 16:17 - 21 Jun 2009    Post subject: Reply with quote
Just to add my experience...
...my '94 CBR6 suffered similar symptoms a few years ago. It would be running fine then suddenly start to run rough and the lights would start to dim. Eventually the bike would cut out and refuse to start.
I replaced the reg/rec and tested the battery to ensure all was fit, but it continued happening. Eventually booked it into a workshop who traced the fault to a melted connector block that was shorting out onto the frame. unfortunately I don't know exactly where the block was in the loom, because I didn't locate it myself and was too stupid to ask at the time.
So as well as the other checks suggested above I'd carefully examine the loom to check that nothing has worn through.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
steo
PostPosted: 16:36 - 21 Jun 2009    Post subject: Reply with quote
that multimeter is ok, you don't have to wait to get one posted to you, your local argos do them for a few quid. if the reg/rec is banjoed then you have to replace it regardless of you fully charging the battery. if it's bo**oxed then the bike will be drawing power directly from the battery to run instead of the electrical system & as soon as the battery starts to go flat then the bike will stop running, you could also fry your battery if it's overcharging. do the tests which timmeh suggested in an earlier thread & you should know if you need a reg/rec.
nomoregt4
PostPosted: 19:55 - 25 Jun 2009    Post subject: Reply with quote
Right, sorry for late update. Instead of buying a voltmeter, I borrowed tonight & the survey said:
With lights off:
12.47 volts @ idle
12.4 volts @ 6k revs
And with the lights on:
12.04 volts @5k revs
So new battery time Rolling Eyes
If it is a case of needing a new battery, will I still need to replace the Rec/Reg box, or was the bad running due to the battery being shot Question
I've just seen the price of a new reg/reg on Wemoto, £60 odd quid Shocked
Thanks again for all your help.
Rich
finpos
PostPosted: 23:11 - 25 Jun 2009    Post subject: Reply with quote
That actually looks a bit like the bike isn't charging the battery at all. So, may well be a problem with the reg/rec. You should also check the wiring - pull apart and re-make all the connections.
Does it work fine for a while after you charge it off the bike?
f.
nomoregt4
PostPosted: 00:39 - 26 Jun 2009    Post subject: Reply with quote
I've not ridden it Finpos since it konked out last. The bike starts fine with the re charged battery hooked up.
Looks like a new reg/rec is needed then Rolling Eyes
Thanks for all your assistance guys Thumbs Up
Rich
The last post was made 17 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 128.33 Kb
