RS125 Cylinder removal engine in frame - special tools?
bmwsport
PostPosted: 21:31 - 18 Jun 2009    Post subject: RS125 Cylinder removal engine in frame - special tools? Reply with quote
Hi guys,
I've whipped my cylinder head off my '51 reg rs125 tonight after the bike gave up last weekend, it cut out and on attempting to re-start it all i could hear was the starter..
Anyway, on removing the head i've found metal shards inbedded in the top of the piston/face of the cylinder head, which i presume to be bits of piston ring.. my question is, how do you guys removal the barrel with the engine in situ? i've managed to get the two front nuts off by using a ring spanner and a mallet, but the rear two (carb side) are very differcult to get at.. any suggestions?
Cheers!
tutton
PostPosted: 21:34 - 18 Jun 2009    Post subject: Reply with quote
youve moved all the battery and coolant hose out the way, then you can get at it with a ring spanner
boundy
micht be better using a socket and extention bar, with the tank, airbox and carb removed might be able to get in there from the top
bmwsport
PostPosted: 21:44 - 18 Jun 2009    Post subject: Reply with quote
Thanks guys.. tutton i've got the two off that are on the header tank side..
I've removed the tank/airbox/carb/reedblock/exhaust/power valve etc to give me as much room as poss, but the frame is stopping me from getting any movement with the ring spanner, might have to try a rachet one.
PostPosted: 21:49 - 18 Jun 2009    Post subject: Reply with quote
You can use a spanner, but probably no chance that you can get a ratchet spanner on them. Thin walled ring spanner should do it.
bmwsport
PostPosted: 21:55 - 18 Jun 2009    Post subject: Reply with quote
Thanks, i was thinking space might be an issue with a rachet spanner.. i'll have a look again tomorrow with a ring spanner, i presume no one torques these up then Laughing
tutton
PostPosted: 21:56 - 18 Jun 2009    Post subject: Reply with quote
you get bit of tension but if your not a little girl a quick crack on each nut going, then unscrew em slowly diagonal fashion.
The last post was made 17 years, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 51.54 Kb
