Fork springs or oil?
PostPosted: 11:01 - 20 Jun 2009    Post subject: Fork springs or oil? Reply with quote
Hi, i need to fettle my suspension, and it looks like fixing the front end will be cheaper. My bike (CB250RSA)is 29yrs old with only 20,000 on the clock, should i replace the springs? and if so recommendations for a good setup i.e spring type / oil type.
Thanks
Pat
steo
PostPosted: 12:04 - 20 Jun 2009    Post subject: Reply with quote
what does 'fettle' mean? must be a ye olde english word? i have three rs's, one is the kickstart model & the other two are the deluxe, all works in progress mind.
Ichy
PostPosted: 12:29 - 20 Jun 2009    Post subject: Reply with quote
What makes you think it needs sorting?
Oil is cheap and can make a big difference if it not been done for a long time. New springs, especially progressive if you can get them, are lovely, but do cost around £70 a pair.
I'd change the oil and check the springs are in tolerance first.
PostPosted: 16:21 - 20 Jun 2009    Post subject: Reply with quote
Well the fork oil had to be changed, and i figured that a spring thats been compressed for that long wouldn't be at its most responsive.
The choice of springs is limited to my flimsy wallet, so no WP etc for me.
Pat
Ichy
PostPosted: 16:58 - 20 Jun 2009    Post subject: Reply with quote
The cheapest springs, if you can get them, are hagon at about £60-70. M and P are doing some reduced price springs from about £20 unfortunately there are none listed for your bike but if you measure the length and diameter of the spring and any spacers Hagon will try to match one for you.
You could try going to a spring manufacturer directly.
Measure the free length of the spring, its surprising how long they last.
Ichy
PostPosted: 17:18 - 20 Jun 2009    Post subject: Reply with quote
I forgot to mention that if your using 10w oil then its worth getting the own brand from Halfords. £7 for a litre and I've used it on several different bikes without a problem.
PostPosted: 22:38 - 20 Jun 2009    Post subject: Reply with quote
Thanks for the advice Ichy, like you say they might be in tolerance but i'm buggered if i can find it in the Haynes. Only mentions the length. Luckily for me i've found some genuine Honda replacements a tenner each. Don't know who makes them but i'll kid myself they're Showa Smile If i'm taking the forks off i might aswell do rebound springs (£3.75 ea)
[EDIT] found the Service limit for the springs..guess what i'm doing tomorrow
Ta
Pat
Ichy
PostPosted: 10:16 - 21 Jun 2009    Post subject: Reply with quote
If your feeling flush then do the bushes and seals at the same time, makes a difference and saves you stripping the forks later on.
When you do the forks give everything a good flushing, all sorts of crud builds up in the most awkward of places.
virus
PostPosted: 11:03 - 21 Jun 2009    Post subject: Reply with quote
I found changing the oil for 10w and putting 10P in 2p pieces in each fork ontop of the springs made a massive change to my forks when I had one, miles better.
John
own: 81 xs1100g...
The last post was made 17 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 63.15 Kb
