Slight Oil Leak.
Davie_G71
PostPosted: 10:50 - 22 Jun 2009    Post subject: Slight Oil Leak. Reply with quote
Hello all, followinf on from something said in this thread about copper washers: https://www.bikechatforums.com/viewtopic.php?t=176755
I have a very slight oil leak and i think it's coming from the banjo boolt as highlighted in this diagram:
https://www.davidaitchison.co.uk/sump.jpg
I thought the washers that were on there previous to me taking it apart were the wrong type, they weren't copper but looked more like steel, so i replaced them with copper ones. But the leak remains.
Should i be heating up washers to the point of glowing and letting them cool before fitting? I thought that copper being a soft metal as standard would crush naturally.
Thoughts?
Suzuki GSXR600 SRAD, 1997 & Kawasaki Z1000, 2003.
iooi
PostPosted: 11:06 - 22 Jun 2009    Post subject: Reply with quote
Is it tightned to the correct figure ?
Are all the joints clean and smooth ?
A new copper washer, should not need anything doing to it to seal the joint.
PostPosted: 11:15 - 22 Jun 2009    Post subject: Reply with quote
I agree with the above. Heating copper washers up is a trick used when reusing them and shouldn't be necessary with new ones.
Suspect the old one was an alloy washer.
Davie_G71
PostPosted: 11:16 - 22 Jun 2009    Post subject: Reply with quote
Yeah, everything is clean and it's as tight as i can possibly get it, granted it isn't torqued up, maybe that's the next step, but it's pretty tight.
It's due an oil change soon so i'll get into it then.
Noxious89123
PostPosted: 11:41 - 22 Jun 2009    Post subject: Reply with quote
Might be overtightened, 25nm isn't alot.
I tightened a bolt to abou 55nm just with a spanner, so if your doing it as tight as you can, it's probably overtightened.
Torque wrench ftw!
Davie_G71
PostPosted: 11:51 - 22 Jun 2009    Post subject: Reply with quote
Hmm - Fair point. I'll get a hold of a torque wrench.
The last post was made 17 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 48.82 Kb
