Problems with wireless
killa
Won't Shut Up
PostPosted: 09:22 - 22 Jun 2009    Post subject: Problems with wireless Reply with quote
My sister is staying our place while she sorts out a new place to live, she needs to be on the net to do her work.
She has a laptop and a wireless netgear card she used at her old flat, she wants to use our connection. We have a BT home hub which with wires works fine, but when we put the her wireless card in, it worked but the signal was VERY bad. We weren't all to far away from the box either, i made sure all the settings were good to go for a laptop but no joy.
So how do i know if its this netgear card or the Hub itself??
I know the router is like some cheap Thompson thing with a fancy case, but it really wasn't far from the laptop.
Any ideas guys?
map
Mr Calendar
PostPosted: 11:19 - 22 Jun 2009    Post subject: Reply with quote
Problems I've had with wireless have been:
Arrow Use the latest firmware in the router
Arrow Change the aerial on the router for a higher gain one
Arrow Move where I use the wireless laptop*
* house is old and has breeze blocks that appear to have a high metalish content that blocks the signal. With router upstairs best signal is (a) in the same room or (b) directly below downstairs.
HTH Thumbs Up
killa
Won't Shut Up
PostPosted: 11:22 - 22 Jun 2009    Post subject: Reply with quote
Where do i get latest firmware from?
Where is the aerial? Where do i get a replacement?
Thanks Thumbs Up
The Artist
PostPosted: 11:24 - 22 Jun 2009    Post subject: Reply with quote
When you have multiple computers using a single router the signal can sometimes overlap if you know what I mean. Automatically they usually set to channel 6. If you go in the router settings and change hers to to 12 or something then it should be ok.
killa
Won't Shut Up
PostPosted: 11:45 - 22 Jun 2009    Post subject: Reply with quote
There's only 1 PC connected and that by wire.
Would it still be affected?
The Artist
PostPosted: 11:59 - 22 Jun 2009    Post subject: Reply with quote
no it wouldn't.
BT Home hubs are notorious for being shite. I suggest you get close you it or build one of the various antenna range extenders you find on the internet?
e.g. pringles can
google it
map
Mr Calendar
PostPosted: 12:13 - 22 Jun 2009    Post subject: Reply with quote
No
FWIW came across this link that covers some of the suggestions already made.
The last post was made 17 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 55.92 Kb
