GS 125 Starting problems still
msmallc
PostPosted: 15:09 - 22 Jun 2009    Post subject: GS 125 Starting problems still Reply with quote
Hi there peeps still cant get my gs125 started.If i put my finger over the spark plug hole and kick it over should the compression push my finger off if so mine dont..Can anyone help please?/??
Ichy
PostPosted: 15:57 - 22 Jun 2009    Post subject: Reply with quote
Yes, compression should push your finger away although its not a very accurate measure.
Your going to need to remove the head cover to make sure the cams and tappets look ok then remove the head to check the valves and piston.
msmallc
PostPosted: 18:04 - 22 Jun 2009    Post subject: just got it started but Reply with quote
Just reset the valve clearances and guess what it started BUT! it will only start using easy start then dies straite away any ideas.................
steo
PostPosted: 18:32 - 22 Jun 2009    Post subject: Reply with quote
could be that the compression is so low that the bike is not able to draw in enough air/fuel mix to keep the engine going. by using easy start or a similar product you're forcing fuel into the engine & so it's starting. have you tried doing a compression test?
msmallc
PostPosted: 18:44 - 22 Jun 2009    Post subject: gs125 Reply with quote
HHavent do a compresion test yet need to get a tester gona go tomorow and get one will let you know how i get on
The last post was made 16 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 42.35 Kb
