1985 honda xr100.... need help with wiring
zxcvbnm
PostPosted: 03:37 - 23 Jun 2009    Post subject: 1985 honda xr100.... need help with wiring Reply with quote
i recenitly bought a 1985 honda xr100 motor for 50$. the only thing that came with motor was an ignition coil (with a black wire coming out of one end and a spark plug wire out of the other end) there is also a black wire coming out from behind the flywheel of where the points are that splits in to. this is the points type of ignition by the way. so im woundering what else would i need to hook this up and make it run? could i just conect the black wire coming out of behind the flywheel to the black wire coming out of the igntion coil and then put a spark plug cap on the end of the spark plug wire. would that do or not? or would i need something called a condenser or something... thanks.
zxcvbnm
PostPosted: 03:45 - 23 Jun 2009    Post subject: forgot to tell u this Reply with quote
yea i also got a 2000 honda xr100 with a CDI ignition on it. the onl thing thats wround with that igntion is that stator coil (it broke somehow) and it costs 209 to replace and im not paying that! yeah so is there anything i could use of the electical system.... let me no. thanks
zxcvbnm
PostPosted: 03:48 - 23 Jun 2009    Post subject: sorry i spelled stuff wroung in my other one Reply with quote
yea i also got a 2000 honda xr100 with a CDI ignition on it. the only thing thats wroung with that igntion is that stator coil (it broke somehow) and it costs 209 to replace and im not paying that! yeah so is there anything i could use of that electical system.... let me no. thanks
zxcvbnm
PostPosted: 03:53 - 23 Jun 2009    Post subject: heres a link to a wiring diagram Reply with quote
https://www.mrcycles.com/fiche_section_detail.asp i dont really under stand that diagram it shows like so many differnt wires on it but i donno. and just to tell u this is a single cilender bike that has never had lights or anything onit, not even a battery, just a kick starter, so ill the ignition system should have to do for me is make a spark.
garyd
PostPosted: 06:32 - 23 Jun 2009    Post subject: Reply with quote
Yep that sounds feasable,connect the black and bolt the coil to the frame (earth) put a cap and plug on and see that big spark,dont go delving into the flywheel area yet ,thats where the points will live ,may need adjusting Thumbs Up
CRF230 all you need
zxcvbnm
PostPosted: 19:32 - 23 Jun 2009    Post subject: ok thanks Reply with quote
yea i had to replace the points on it anyways im ordering them now. i have a kill botton off my newer xr 100 right. to hook that up would i just put one wire off the kill botton in the other wire coming out of the flywheel. (since theres 2 coming out of there one that hooks up to the coil and im Guessing the other one could hook up to the kill botton and ground the other wire of the kill bottom to the frame. could i do that? and how do i test if the stator coil and points are working (becuase im not that shure that the points are gone ( the guy said they might be) ....... so then i could test if i even need points or not ....thanks
The last post was made 16 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 48.65 Kb
