| Majik |
 Majik Derestricted Danger
 Posted: 13:27 - 24 Jun 2009 Post subject: Using a smaller battery... |
I'm rebuilding my Goose, and relocating the battery, but it's a huge bugger (ytx-12bs). The engine is from a dr350s (electric start) which uses the YTX-4 LBS which is tiny, which would fit perfectly under the seat (where I want to relocate it). The CCA difference in the batteries is pretty big, but what am I risking by going with a smaller battery here? Is it purely less cranks on the starter button?
Cheers,
Majik ____________________ www.suzukigoose.co.uk |
| Blue_SV650S |
 Posted: 13:52 - 24 Jun 2009 Post subject: Re: Using a smaller battery... |
| Majik wrote: | I'm rebuilding my Goose, and relocating the battery, but it's a huge bugger ( ytx-12bs). The engine is from a dr350s (electric start) which uses the YTX-4 LBS which is tiny, which would fit perfectly under the seat (where I want to relocate it). The CCA difference in the batteries is pretty big, but what am I risking by going with a smaller battery here? Is it purely less cranks on the starter button?
Cheers,
Majik |
I am not sure what a Goose is, but if the battery is the one that is meant for the motor (not the chassis), then it should provide enough oomph to start it, it should also be set up to provide enough amperage on the re-charge too ...
So I'd say its sounds fine to me
The only thing you need to check is the wiring of the reg/rec unit i.e. are they both a 5 wire system? ____________________ The purpose of life is to fight maturity. |
 Posted: 17:06 - 24 Jun 2009 Post subject: |
Try it - I once had a GPZ600 that use a sealed lead-acid battery out of a fire alarm panel, complete with tiny spade terminals. It was fine for the whole time I owned the bike. ____________________ a.k.a 'Geri'
| Majik |
 Posted: 08:53 - 25 Jun 2009 Post subject: |
My concern about giving it a go is, with it being a bigish single, whether I'm going to have enough power to churn the thing over with the smaller battery. Ignorance rules when it comes to CCA, amps etc... ____________________ www.suzukigoose.co.uk |
| Blue_SV650S |
| Majik |
 Posted: 09:59 - 25 Jun 2009 Post subject: |
Fair point, well made. I need to stop messing around and get it done Cheers SV! ____________________ www.suzukigoose.co.uk |
The last post was made 16 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
