Find me a computer
Robby
Dirty Old Man
PostPosted: 21:45 - 24 Jun 2009    Post subject: Find me a computer Reply with quote
I'm looking to buy a new computer. This is mainly going to be a media centre, plugged into a big TV with a VGA cable, but it will also be used to play some games - command and conquer type stuff.
Last time I knew anything detailed about the components in my computer a PII 400 with a pair of voodoo 2 graphics cards was cutting edge. I am led to believe that this is no longer the case.
Thing I want:
Small case, like a shuttle PC.
Really, really quiet.
1TB hard drive
wifi built in
twin core or better processor
4gigs or more of RAM
No blue lights on the casing. I'm not eleven.
Don't need a screen, and I'll find myself a wireless keyboard and trackball for sofa use. Budget is less than £500, and the cheaper the better.
Tarmacsurfer
PostPosted: 22:06 - 24 Jun 2009    Post subject: Reply with quote
To throw a slightly different take onto it, I use a refurbed laptop for a media centre. There are even HDMI laptops around now (although given I'm using an older one that came my way broken it's connected via VGA), this has a huge advantage in the fact they're generally very, very quiet and easy to hide away and usually have a very good wireless connection.
I use THIS SETUP to drive it from the sofa, keyboard is small enough to slot underneath and out of sight when unwanted and the remote drove most of my kit until I went for an LCD programmable unit for general use. Can pick them up for much less than retail via Ebay and suchlike, paid £20 for mine as the keyboard was damaged. You also have the advantage with the laptop form factor that if you want to take it elsewhere it's easy to do so.
I'm immortal. Well, so far.
Finglonga
PostPosted: 22:07 - 24 Jun 2009    Post subject: Reply with quote
32 or 64 bit? If 32 you will only want a maximum of 4 Gig RAM as it wont use any more.
Andy Sez....
F.Y.Y.F.F.
Robby
Dirty Old Man
PostPosted: 22:34 - 24 Jun 2009    Post subject: Reply with quote
Interesting, however the laptop has the issue of being expensive to upgrade, taking smaller hard drives, and generally having inferior graphics cards. I have also realised that I might be flexible on the wireless - this is going to be near my xbox 360, so I might as well plug them both into the router.
32bit for now, seeing as I'm sticking with XP, so 4 gig is all I need.
JonB
Afraid of Mileage
PostPosted: 07:10 - 25 Jun 2009    Post subject: Reply with quote
Regarding your OS choice i'd be tempted to go for Vista purely because you get Media Centre included, i'm pretty sure you can't get XP Media Centre edition off the shelf anymore (presuming you were going down the legit route). That way you can use your Xbox 360 as an extender as well.
I wouldn't worry about the scare stories, it's a mature OS now (upto Service Pack 2). I'm not using it though as I am using Windows 7 on a daily basis now, but it is essentially Vista but with much better performance. Smile
Tarmacsurfer
PostPosted: 11:18 - 25 Jun 2009    Post subject: Reply with quote
Valid points, all of which I will counter by saying that any small form factor unit be it a half height AV case like Luke's or a shuttle will give very similar problems, particularly with a requirement for silence. Not all, but certainly most decent graphics systems are inherently noisy. Whilst passive cooling does work if set up right it's not common on low rise cards as the surface area isn't really big enough so you're left with board integrated solutions ie "inferior graphics".
After a quick look around you'd be using something like THIS CARD to upgrade that media case (the mobo Luke has in it isn't at all bad, no idea on the chip), HERE'S a review of the card. In terms of OS, like Jon I've started using Win 7 as my M$ OS of choice, most of my boxes now run it and Ubuntu as dual boots with one or two other *nix flavours in assorted places.
Robby
Dirty Old Man
PostPosted: 12:25 - 26 Jun 2009    Post subject: Reply with quote
Trust the geek zone to make things complicated.
Luke, I may take you up on that - how many cores is the processor?
An alternative may just be to get a full size casing, I assume these can still be sufficiently quiet? My cheap acer at home is, just back in the day anthing vaguely quick was noisy.
UnknownStuntm...
PostPosted: 15:50 - 26 Jun 2009    Post subject: Reply with quote
I've built loads of Shuttles recently, based on the K45 and the X27d. K45 will accept standard intel chips, so if you get a reasonable one with a 4 conductor fan cable, it'll be dead quiet. They'll take a driver, but you'll have to mod the front panel to do so, so be aware of that.
X27, atom based, so maybe games will hammer it a bit much. But they really are silent. You can put more RAM in an X based Shuttle, but the processor is part of the motherboard.
hth.
Charlie
PostPosted: 08:32 - 28 Jun 2009    Post subject: Reply with quote
Mac mini sounds like it fits the bill...
Rob
PostPosted: 00:32 - 29 Jun 2009    Post subject: Reply with quote
Almost... except for the playing games bit! If they aren't mac games you would have to end up using boot camp and running windoze that way, which does work well but knowing how fussy games can be there may be some issues? Maybe not?
The Mac Mini is by far the best form factor for a media/sitting room/bedroom PC though! Thumbs Up Laughing
Love is 1050cc Smile
UnknownStuntm...
PostPosted: 06:46 - 29 Jun 2009    Post subject: Reply with quote
Don't need boot camp any more, just format the disk as fat32 and stick your XP disc in. BUt feck me aren't they expensive now??
neil.
PostPosted: 07:22 - 29 Jun 2009    Post subject: Reply with quote
If you do want a Mac Mini, robby, PM me as I can get you a 10% discount on one from the Apple Store (working in education).
The last post was made 17 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 75.27 Kb
