Brake lever balls.
Knacker
PostPosted: 07:59 - 23 Jun 2009    Post subject: Brake lever balls. Reply with quote
Will my bike fail its Mot if it doesnt have a ball on the brake/clutch lever Question
Thank you Smile
Previous: K1 GSXR 1000
PostPosted: 08:00 - 23 Jun 2009    Post subject: Reply with quote
I believe so. Although I could be getting confused with the ACU regulations. Confused
Davie_G71
PostPosted: 08:09 - 23 Jun 2009    Post subject: Reply with quote
I'm pretty sure it will as it's there to protect pedestrians.
Suzuki GSXR600 SRAD, 1997 & Kawasaki Z1000, 2003.
Ichy
PostPosted: 08:43 - 23 Jun 2009    Post subject: Reply with quote
In theory its a fail, comes down to how well they do their job.
An insecure brake control or mounting. Attachment screws loose or missing. A cracked control lever or mounting.
a control which is inoperative or so damaged, positioned, bent or shortened that the brake cannot be readily applied
deliberate modification which significantly reduces the original strength of any component. Excessive corrosion, severe distortion, a fracture or an inadequate repair to a component.
I guess, according to interpretation, any of the above could be used as a reason for failing.
yen_powell
PostPosted: 08:57 - 23 Jun 2009    Post subject: Reply with quote
Bit of epoxy resin formed on the end into a ball will sort it. My mate did a few of my old ball less levers for my DR and they lasted longer than a new lever would've. No problems at MOT time either.
XT1200Z and a DR350 in bits
stirlinggaz
PostPosted: 09:22 - 23 Jun 2009    Post subject: Reply with quote
hi,
as above.
but i've used araldite metal putty.
quickly sand the old lever.
form the putty into a ball shape & stick on the end.
dries in grey, almost metal coloured.
then a quick spray with whatever spray paint you have lying around. (silvers best obviously)
tester wont know the difference.
probably last a few days though, lol
if you dont have any of the above stuff lying around, probably be cheaper buying a new lever.
i know of one mechanic who has the remains of a lever or 2 in his workshop.(the ball shaped part)
& when he takes your bike for the mot, he just glues the ball on!
cheers,
GAZ
mr rip
PostPosted: 22:01 - 24 Jun 2009    Post subject: Reply with quote
ball ends on leavers are only a requirement for racing, not MOT
the end has been busted off the front break of my armstrong for three years & the guy who MOT's my bikes (who's a real stickler & fails it on something new every year, even if he passed it the year before) hasn't mentioned it once
never criticise a man until you've walked a mile in his shoes, then when the muck hits the fan you'll be a mile away & you'll have his shoes
finpos
PostPosted: 23:06 - 24 Jun 2009    Post subject: Reply with quote
If it's stabby, it should fail. Unless it's an ancient bike, in which case OEM stabby is allowed. Old bikes were better because they were more stabby.
f.
PostPosted: 09:59 - 25 Jun 2009    Post subject: Reply with quote
Just file it down so it isn't sharp, I'm pretty sure it would pass then.
The last post was made 16 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 59.44 Kb
