Auto electricians
binge
Emo Kiddy
PostPosted: 22:29 - 24 Jun 2009    Post subject: Auto electricians Reply with quote
Got a wiring issue I think.
TZR engine, Running without a battery.
All it has to power is a Horn, A 20w Halogen Headlight, And an LED tail light. NO other power drains other than the engine ignition.
I had been running it with no headlight for a while as the bulb had gone, and hadnt got round to replacing it.
Today I bought a bulb, First time its had a headlight bulb since the build. Put it in, Worked fine.
On idle, Its pretty bright, And at very low revs, Its brighter.
But once you wang the throttle open, It goes really dim.
But get this, On the motorway, I was pinned at about 70mph, Full throttle. And when I pressed the horn, The headlight got brighter. Confused
Completely baffled me.
It's as if its working back to front.
Ben
finpos
PostPosted: 22:49 - 24 Jun 2009    Post subject: Reply with quote
Do you have a regulator / rectifier in there somewhere, and are you running the lights etc off the regulated 12V?
If you are, you may need to stick a battery in it, or a big capacitor (sometimes sold as battery eliminators), the battery is quite an important bit of the rectifier's action Smile
f.
binge
Emo Kiddy
PostPosted: 22:58 - 24 Jun 2009    Post subject: Reply with quote
I am running everything after the regulator yes.
I thought it was that too. But surely when it revs up, The power output increases, So the bulb should get brighter. Not dimmer.
And then when I use the horn, The bulb goes really bright again.
Ben
mad_revs
PostPosted: 23:10 - 24 Jun 2009    Post subject: Reply with quote
i have run a 2 stroke with a knackered battery and headlight got broghter when revved bit i would of thought taking it out all together will cause strange symptoms like what your describing.try sticking a new battery on the bike its only 15 quid max and if it cures the problem it saves messing about with a auto electrician
mr rip
PostPosted: 23:39 - 24 Jun 2009    Post subject: Reply with quote
it sounds like you have an earth problem, ie the earth for the light is running in series with the horn hence it works better with the horn button pressed
check that you don't have the earth & power supply leads to the handlebar switchgear mixed up as that would do it.
the same as the way the alternater light works (by having two positives while alternator is running)
next, try running a new earth lead from the light down to a clean bit of frame
if that doesn't help then try putting a new lead in from the supply to the switchgear
never criticise a man until you've walked a mile in his shoes, then when the muck hits the fan you'll be a mile away & you'll have his shoes
finpos
PostPosted: 23:44 - 24 Jun 2009    Post subject: Reply with quote
Problem is the battery acts to smooth all the noise in the regulated supply. It's the noise that is probably causing the bother.
Putting any load on the electrics (like the horn) will also help smooth things out, which is why it's probably having an effect, although I expect there to be additional electrical ju-ju going on because of how horns work.
f.
Blue_SV650S
PostPosted: 00:17 - 25 Jun 2009    Post subject: Reply with quote
Its behaving exactly as I'd expect! Thumbs Up
If you haven't got a battery in there to suck up some juice and smooth things down, then your poor old reg/rec is having to work overtime mind - poor reg/rec Crying or Very sad
binge
Emo Kiddy
PostPosted: 18:45 - 25 Jun 2009    Post subject: Reply with quote
It shouldnt need a battery. I took the battery off my pit bike engine and it all ran fine.
I've totally re-wired the headlight today, Going directly from, And back to the regulator + and -. And the problem hasn't changed.
Got a multimeter on the Reg/rec output. On tick over it is kicking out around 17 or 18 volts!
And when I rev it, The voltage drops to around 10 or 11 volts.
I've bought a replacement reg/rec off ebay. Hopefully that will sort the problem.
Ben
finpos
PostPosted: 19:07 - 25 Jun 2009    Post subject: Reply with quote
Ben
..probably because you've removed a major chunk of the rectifing circuit, aka. the smoothing capacitor, aka the battery. You're basically getting a big fat load of un-smoothed half-wave AC out of it instead of anything approaching DC.
Ben
...that's the regulating component kicking in as the voltage rises, again, any voltage disparity probably due to the fact you're measuring AC and not DC.
Your pit bike probably ran all of it's lighting off an unregulated supply. Battery possibly ran the indicators.
f.
binge
Emo Kiddy
PostPosted: 19:52 - 25 Jun 2009    Post subject: Reply with quote
How is it measuring AC after the Reg/Rec? I'm measuring a DC output surely?
Ben
Blue_SV650S
PostPosted: 20:39 - 25 Jun 2009    Post subject: Reply with quote
Ben
It has to be DC if its gone through the rec, but the voltage is going to be all over the place without the battery to smooth things out! Its no wonder you are getting odd readings. Stick a battery on it or connect it to a car battery) and see if all seems normal again. Wink
finpos
PostPosted: 23:22 - 25 Jun 2009    Post subject: Reply with quote
To use an analogy - it's like you've taken the dampers off your suspension. It'll still work, it's going to be all over the shop.
f.
the grim reaper
PostPosted: 12:06 - 26 Jun 2009    Post subject: Reply with quote
This advice above is all correct, the battery acts as a load across the alternator which is required for proper operation. Even though it is effectively downstream and the other side of the reg/rec, having an expected large capacitive load mossing from the circuit will affect all components.
The other possible issue is that you no longer have a common earth. On some bikes you have more than one earth connector going to the battery, if you haven't connected the earths together then certain parts of the bike could be floating, away from 0VDC.
Grim
The last post was made 17 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.43 - MySQL Queries: 13 - Page Size: 77.71 Kb
