| D O G |
 D O G World Chat Champion
| Timmeh |
 Timmeh World Chat Champion
| D O G |
| steo |
 steo Nova Slayer
| Feasty |
 Feasty World Chat Champion
 Posted: 15:49 - 26 Jun 2009 Post subject: |
Don't know so much about your lights pulsing when you're riding along... but I've always found my bikes front lights pulse a little when I'm indicating, I think that's pretty normal and is just power being diverted from the front light to the indicators.
Also I've had heated grips on my past 2 bikes and when they're on during winter the front light does pulse a little. However I've never had any problems with the bikes not starting (unless I don't use them for a few weeks ).
So I'd say so long as the bike starts fine and your lights aren't being majorly affected then don't worry about it... you'll soon notice your battery is buggered when the bike won't start even after an overnight charge...  ____________________ Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed). |
| defblade |
 defblade World Chat Champion
 Posted: 21:27 - 26 Jun 2009 Post subject: |
Check, clean and tighten the earths. Almost always the problem with lights affecting each other as they tend to be earthed to the same spot, and if the earth is not 100%, one circuit starts playing hooky with another.
If it's a real problem, could be worth using the original wiring to switch a relay and give the headlights a new (and fused!) high capacity feed from the battery. ____________________ Honda Varadero 125cc => Suzuki Bandit 650 33bhp => 77bhp =>
BMW K1200R Sport 163bhp => Aprilia Shiver GT 750 95bhp |
| smegballs |
 smegballs World Chat Champion
| defblade |
| smegballs |
 Posted: 19:20 - 27 Jun 2009 Post subject: |
Bad Earths seem to be right bastards....
And they seem to have really weird and wonderful symptoms!
Dont suppose intermittent charging would be another sign of these little devils?
Rich |
| defblade |
 Posted: 13:37 - 28 Jun 2009 Post subject: |
Less likely I'm afraid as the charging circuit should be pretty heavily and directly connected to the battery* and so an earth problem here would probably be giving you fun with every single electrical system on the bike.
*I should point out that my experience is in car electrics, I'm quite new to bikes; whilst I'd be amazed if the lighting problems mentioned aren't down to bad earths (and the next suspect is worn/broken/shorting wiring), once we're into charging circuits and so on, I'm going on general priciples. ____________________ Honda Varadero 125cc => Suzuki Bandit 650 33bhp => 77bhp =>
| smegballs |
 Posted: 15:22 - 28 Jun 2009 Post subject: |
Ok my symptoms are:
Intermittent Charging - Sometime about 13.5V other times about 12.4-12.9V. Never overvoltage
Headlights go dimmer when throttle is blipped, normally they would get brighter! Accordingly voltage across the battery drops from say 12.6V to 12.3 V when throttle blipped.
Ive just run thickish 17Amp cable from the headlight earth to the frame, from the reg output to the frame and a double length from the battery to the frame.
Ive made a clean earth connection and cleaned all the new earth connections.
Earthing for vital systems now should be OK I would of thought, anything else to check?
Sorry for stealing your thread Damofo but hopefully something good may come up for you
Rich |
| MattEMulsion |
 MattEMulsion World Chat Champion
| smegballs |
The last post was made 17 years, 76 days ago. Instead of replying here, would creating a new thread be more useful? |
