Bike feels 'weird'
Ant132
PostPosted: 19:58 - 27 Jun 2009    Post subject: Bike feels 'weird' Reply with quote
Hi, today i was out riding and the bike just didnt feel right, i knew something was wrong because it didnt start as it normally does, it was very hesitant.
But i thought nothing of it and went out anyway, only find that when accelerating it feels, again, quite hesitant. Idling it feels as though it wants to cut out but doesnt quite, the power seems to have dropped too. Low speed is jerky and stuttery.
My first thought was that maybe i need to go onto reserve but no, i pulled over and tried reserve but still the same. Filled up with petrol on the way back to find that it took a few seconds more to start as opposed to instantly, like it usually does, and then just saved itself from cutting out when i put it in gear.
Any ideas of things to check? Ant Thumbs Up
(Worth noting: The bike (Superdream) has recently had its carbs balanced and a top end rebuild last month.)
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
Timmeh
PostPosted: 20:12 - 27 Jun 2009    Post subject: Reply with quote
my money would be on a shagged sparkplug, so have a look before you go silly and tear the engine apart.
Ant132
PostPosted: 20:20 - 27 Jun 2009    Post subject: Reply with quote
Thanks. Dont worry i wont be tearing into it just yet, im hopefull its something minor but im not sure what. The plugs are quite new (a month or two old) but gotta be worth a try Smile
Timmeh
PostPosted: 20:25 - 27 Jun 2009    Post subject: Reply with quote
Just because they are new, it doesn't mean that they're correctly gapped. Incorrect gapping can result in weak spark (too long) rapid electrode wear (too short) or problems like you are describing.
Ant132
PostPosted: 20:27 - 27 Jun 2009    Post subject: Reply with quote
Thanks mate. Will get some in the morning then Thumbs Up Smile
smegballs
PostPosted: 20:35 - 27 Jun 2009    Post subject: Reply with quote
Too True!!
On my GS400 it wouldnt run/start.
Took plugs out and the gaps were quite small with a shitty weak spark. Now logic to me would be that smaller gap means easier to jump hence better spark.
No Chance!!!
Once they were properly gapped made quite a bit bigger, the bike
had big fat blue sparks and started almost at once! Thumbs Up
Seems weird but plug gap really does make a BIG difference.
Rich
PostPosted: 23:59 - 27 Jun 2009    Post subject: Reply with quote
Also worth checking for airbox leaks, and clean secure air filter (my bike was running abit ropey, i hadn't seated the filter properly Embarassed )
Pat
The last post was made 17 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 54.28 Kb
