price of a caliper strip down and repair??
ikkledivel
PostPosted: 11:24 - 29 Jun 2009    Post subject: price of a caliper strip down and repair?? Reply with quote
Just a quick question..
How much do people think i should be expecting to pay for a full caliper strip down and repair (piston seals popping out after a cleaning disaster!), cleaning of the other front and back brake and replacement of the headstock bearing (and possibly the front wheel bearing!)??? Im just trying to get a rough idea of a price as i dont honestly have a clue but also dont want to be "taken for a ride" due to being an inept mechanically minded girl Shocked Laughing
Also does anyone know of a decent garage I can go to around the manchester university area??
Thanks
Nic
ps its a gsxr 600 srad 99 if that makes a difference...... Rolling Eyes
Current bike - Triumph Daytona SE 09 (white & blue). Previous bikes. Suzuki GSXR 600 SRAD, Aprilia RS125 02 (sold) "Reality is a nice place to visit, but I wouldnt want to live there!!" Smile
Many many months of 2 stroke mastery before Direct Access Pass: 04/03/09 Smile
PostPosted: 11:34 - 29 Jun 2009    Post subject: Reply with quote
For the calipers it is a touch more difficult being 4 piston calipers (it is very easy on twin piston sliding calipers), just purely because there is probably not enough clearance to get the pistons out before splitting the calipers. New seals (and possibly pistons) will add to the price. Assuming nothing too nasty then maybe 3 hours labour from a decent mechanic to remove the calipers, strip them down, clean them up, replace the seals / pistons, refit and bleed the system (this is assuming both calipers). They might manage to do it a bit quicker.
The Suzuki rear calipers are a total pain. The pins that hold the pads in place seize in position and make life difficult. As such cleaning it up could be a simple short job or a nightmare, depending on how well maintained it has been in the past.
Steering head bearings are a couple of hours work as the forks, etc need to come out.
ikkledivel
PostPosted: 11:52 - 29 Jun 2009    Post subject: Reply with quote
So im looking at a fair amount of cash then in worse case scenario and a month of living on beans on toast....?? Crying or Very sad
Ive only had the bike since march and have tried to keep on top of the basic maintenace and when bought it had had a full service, so hopefully the back brake shouldnt be in too bad a shape (the gunk on the front wasnt too bad in all honesty) but unfortunately im not sure how well kept it was before me.
PostPosted: 11:57 - 29 Jun 2009    Post subject: Reply with quote
They are time consuming jobs and thus not really that cheap to pay for.
Doing the front calipers shouldn't really be that easy. There might well be someone on here local to you who can help you do it.
Rear calipers are random. If the pins are free then it will probably be easy. Most Suzukis seem to use basically the same rear caliper, and I assume your GSXR does.
Do the steering head bearing need replacing? When they do you will probably feel some notchiness in the movement of the bars when the front wheel is held in the air.
ikkledivel
PostPosted: 12:18 - 29 Jun 2009    Post subject: Reply with quote
Hi keith
thanks for your responses so far, i really appreciate the advice.Thumbs Up
im not 100% sure regarding the steering head bearing, i just noticed it started squeaking/squealing when turning the bike to the right every now and then and nothing seems to be catching which could cause it. A search on here seemed to suggest this may be the problem but like everything else it could mean a thousand other things...... Any other ideas will be greatly appreciated of course
Very Happy
I just thought that as the bike would be going to the garage it may as well get everything thats niggled me sorted out....
thanks again
nic
PostPosted: 12:24 - 29 Jun 2009    Post subject: Reply with quote
Doesn't really sound like they need replacing. I suspect if they were so wrecked to be making a noise that the handling would be awful.
Steering head bearing replacement is a job I hate. So much faffing round removing the front end just to replace a couple of bearings.
Noxious89123
PostPosted: 21:12 - 29 Jun 2009    Post subject: Reply with quote
Cost about £100~£150 to have my front calipers stripped iirc.
Whosthedaddy
PostPosted: 08:54 - 30 Jun 2009    Post subject: Reply with quote
Yep, cost me £170 if I remember for the 7R 6 pots and about £130 for the FZR front and rear strip down. That included all the copious amounts of seals and several hours of labour. God damn expensive if you ask me but worth it for less headaches afterwards.
Davie_G71
PostPosted: 11:11 - 30 Jun 2009    Post subject: Reply with quote
I have a 97 SRAD and have re-built the calipers myself, it's not a difficult job, but it is time consuming.
If you are reasonable confident and have the workshop manual (i can supply this if you need it) then have a go.
They aren't complicated bikes.
Suzuki GSXR600 SRAD, 1997 & Kawasaki Z1000, 2003.
ikkledivel
PostPosted: 11:40 - 30 Jun 2009    Post subject: Reply with quote
Ive no doubt I could do it if i put my mind to it.... but to be honest im not a patient person at the moment and ive not really got the time to spare as im writing my thesis in my spare time Sad so ill be opting for the easy and costly method of getting someone else to do it. Ive had a reasonable quote from mr.pigs in manchester so going to take it down there and hope its a relatively straight forward job Very Happy
Thanks again for all the replies
nic Very Happy
Davie_G71
PostPosted: 12:01 - 30 Jun 2009    Post subject: Reply with quote
Fair enough. It does take time and is fiddly. The most frustrating part is the bleeding afterwards. That's a PITA.
Head bearings are easy as well, but you need something to support the bike whilst the front end is off.
D O G
PostPosted: 15:20 - 30 Jun 2009    Post subject: Reply with quote
That's easy for you to say. Crying or Very sad
TUG
PostPosted: 19:47 - 30 Jun 2009    Post subject: Reply with quote
SRAD calipers are a complete PITA, I rebuild mine and i have no pressure i think its down to "seal roll" i know one person on here has rebuild theirs and has bled them 8 times by 4 different people...
Haz ER-5, innit!
Davie_G71
PostPosted: 09:07 - 01 Jul 2009    Post subject: Reply with quote
If the seals are rolling then they need replaced - and when they are replaced they need to be dipped in fluid to keep them supple.
I've learned all this the hard way.
The last post was made 17 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 89.02 Kb
