Fork oil and seals
Hunter
PostPosted: 17:54 - 17 Jul 2002    Post subject: Fork oil and seals Reply with quote
Hey Guys!
Can you change fork oil and seals without taking the fork tubes off the bike?
I just figured it might be easier to take the lower (mine are not inverted forks) cylinders off with the fork tubes attached to the handle crown.
Any Ideas?
Cheers Smile
Smile
Hunter
PostPosted: 18:27 - 17 Jul 2002    Post subject: Reply with quote
Oh and also... do you have to use a fork seal driver tool (as mentioned in the workshop manual) or can you use any other tool or improvise?
Cool
Annabella
Like a person, only smaller
PostPosted: 21:33 - 17 Jul 2002    Post subject: Reply with quote
It's just as easy to take the whole lot apart, if you strip the front forks down, change the seals, bushes dust covers etc, and put it all back together, then pour in required amount of oil it should only take you a couple of hours max. Cool
Just make sure you put your speedo gearbox on the wheel bearing the rigth way round otherwise you'll end up with a smashed one like I did! Shocked
Avast! Pirates ahoy!
I did Cadwell! Very Happy
Dan
PostPosted: 23:01 - 17 Jul 2002    Post subject: 1 Reply with quote
is it easy to change the seels urself? how long does it take and how much are they?
Hunter
PostPosted: 20:00 - 19 Jul 2002    Post subject: Reply with quote
Thanks for the help !! Do i need a fork seal driver tool to insert the seal or can I improvise using another tool?
captain gungadera
PostPosted: 21:59 - 19 Jul 2002    Post subject: Reply with quote
don't worry about a broken speedo at least your's broke for a reason my needle just came off one day!!
Mighty moving meat pie, low output power, park ranger!!!
The last post was made 23 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 45.58 Kb
