Fuel gauge wont work
seantobin43
PostPosted: 22:18 - 29 Jun 2009    Post subject: Fuel gauge wont work Reply with quote
I bought a 2007 yamaha aerox and when i turn the ignition on it only moves a very small bit , i looked in the fuel tank and i think there is alot more fuel in it
SEAN TOBIN Very Happy
PostPosted: 22:57 - 29 Jun 2009    Post subject: Reply with quote
Fill the tank up fully and then report back with what the gauge does then.
B10Hazard
PostPosted: 01:33 - 30 Jun 2009    Post subject: Reply with quote
Might be a dodgy sender unit.
Not giving you the correct fuel reading.
No longer any socks
seantobin43
PostPosted: 18:25 - 30 Jun 2009    Post subject: Reply with quote
i filled it up with petrol . The fuel gauge is telling me it is empty i toke the the fuel sensor out and turned it up side down then the fuel gauge goes up and tells me its full . Is the fuel sensor broken.
Hutchysrs50
PostPosted: 20:12 - 30 Jun 2009    Post subject: Reply with quote
i would think so...
it will only be a piece of sponge floating up and down a small plastic pipe ( i think)
Gilera SC 125 - Current
Noxious89123
PostPosted: 20:20 - 30 Jun 2009    Post subject: Reply with quote
Swap the 2 wires coming out of the sensor around?
finpos
PostPosted: 21:48 - 30 Jun 2009    Post subject: Reply with quote
They tend to wear out, nothing much you can do except replace the sender.
f.
Mr Hammers
PostPosted: 10:30 - 01 Jul 2009    Post subject: Reply with quote
Bit of a bodge, but can't you put it back in upside down if it works that way..? Maybe it was put back in the wrong way before...?
A Guide To Powerbands
seantobin43
PostPosted: 11:09 - 01 Jul 2009    Post subject: Reply with quote
but can't you put it back in upside down if it works that way..? [quote]
you cant put it upside down
Mr Hammers
PostPosted: 11:28 - 01 Jul 2009    Post subject: Reply with quote
Ok, how about what Noxious suggested...swapping the wires around. Have you tried that?
seantobin43
PostPosted: 19:15 - 01 Jul 2009    Post subject: Reply with quote
yep i did doesn't work
seantobin43
PostPosted: 19:23 - 01 Jul 2009    Post subject: Reply with quote
wont work when i did that
Noxious89123
PostPosted: 22:41 - 13 Jul 2009    Post subject: Reply with quote
Bummer.
Tried running the bike on an empty tank? Laughing
ZaphodBeeble
PostPosted: 00:39 - 16 Jul 2009    Post subject: Reply with quote
What kind of fuel sensor is it? Has it got a float with an arm? If so, try putting the float into a container of fuel and see if it floats properly. I had a problem with a fuel sender recently; I tried it in a bowl of water and it floated ok but wouldn't float in fuel.
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
There is a gap of 1 year, 32 days between these two posts...
goldman
PostPosted: 12:05 - 17 Aug 2010    Post subject: Reply with quote
[quote="seantobin43"]i filled it up with petrol . The fuel gauge is telling me it is empty i toke the the fuel sensor out and turned it up side down then the fuel gauge goes up and tells me its full . Is the fuel sensor broken.[/quote]
I have the same problem --- please can someone tell me where I find the sensor so that I can test it out or replace it?
Thanks,
Nick Goldman (newbie)
The last post was made 16 years, 30 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.84 - MySQL Queries: 16 - Page Size: 90.37 Kb
