 juliansellars... L Plate Warrior
 Posted: 13:54 - 30 Jun 2009 Post subject: |
Seemingly silly question: Is the chain still attached to both the engine and the rear wheel?
My number 1 suspicion from what you describe would be that the front sprocket has come off the splines or the chain has come off the sprocket.
I presume it is actually going into gear, lever moves as normal, slight clunk, neutral light goes out?
I can't think of anything simple/likely that would abruptly happen to a clutch which would cause those symptoms. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
 Posted: 15:02 - 30 Jun 2009 Post subject: |
I find it HIGHLY unlikely that the clutch would have catastrophically failed in such a way as it is permanantly disengaged while stopped at the lights.
Only time I've seen that happen was following a prolonged burnout and the resulting noise left one in no doubt as to the nature of the failure.
One suggestion is that the primary shift mechanism could have either worn or broken. There are a couple of little "hooks" that grab the gear selector drum and pull it round into position. The ends of these hooks can wear round so they don't get hold or the small spring that holds the hooks in position could have pinged off.
Fortunately, unlike many bikes, the GPZ has the shift mechanism under its own little cover on the left hand side under the front sprocket. It's a fiddle but you can remove it with the engine in the frame. If you're draining the oil to check the clutch and find nothing, check under there too. It's a paper gasket. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
