Burbling hesitance below 5k
Visitor Q
$25 whore
PostPosted: 18:05 - 29 Jun 2009    Post subject: Burbling hesitance below 5k Reply with quote
CBR 600 FT (1996)
Hi guys, the hack has been burbling a bit at low revs, and bogging down. It used to only be noticeable when pulling away gently, where I found myself bogging until about 15mph, then it was fine.
Now it's doing it when moving, as mentionned it seems anywhere below 5k.
Still merrily does 150plus, so I don't think it's general fuellng (despite the slight smell of petrol its developed, and yes i've checked the pipe are on correctly).
My guess is the smaller of the needle jets? I've whacked ia whole 'one shot' of redex, which doesn't seem to have changed much, exept now it makes a weird kind of vibrating burble at certain revs occasionally.
What do you think? inline 4 with a sod of a carb to work on, so I'd like some other idea. I also had carb balancing done recently, any danger they fettled the wrong part?
Irritating as it kind of feels like when you have to change to reserves, but as mentioned, it's fairly random. So not suited to london traffic.
(nhs keyboard sorry)
carlperkins00...
PostPosted: 19:32 - 29 Jun 2009    Post subject: Reply with quote
i have the same problem with my hornet 600. riding slowly (less than 15mph) it feels juddery and rough but as soon as i pick up the speed its fine.
if you find out the problem... let me know?? Laughing
Blue_SV650S
PostPosted: 19:53 - 29 Jun 2009    Post subject: Reply with quote
When was the last time you changed the plugs!?!? Wink
Robby
Dirty Old Man
PostPosted: 20:08 - 29 Jun 2009    Post subject: Reply with quote
90% of carb problems are electrical. Standing tends to gum up carbs, regular use keeps them clean, all the petrol flowing through does that, and I think you replaced the fuel filter fairly recently.
Spark plugs would be my first port of call. I would also change HT leads, but seeing as these can be expensive try new plugs and a good bit of WD40 on the HT leads.
Also have a look at the reg/rec to make sure it hasn't melted away, and check that the HT leads and LT wires are secure on the coils.
PostPosted: 21:12 - 29 Jun 2009    Post subject: Reply with quote
Plugs would be my first thought rather than fuel... As usual in the Workshop I agree with the Captain.
Visitor Q
$25 whore
PostPosted: 22:45 - 29 Jun 2009    Post subject: Reply with quote
Haha, I had a horrible feeling you would say that.
Guess what I replaced mine with... Iridiums Neutral
About 2 months ago.
Weird for it to suddenly cause a problem now though Thinking
The fact it would still wheelie and do 150 at strongly made me think it couldn't be fuel/air supply difficulties.
Ah well, I'll have a look.
temeluchus
PostPosted: 01:57 - 30 Jun 2009    Post subject: Reply with quote
I doubt the iridium plugs will cause any problems. Ive run them on a variety of bikes and theyve always worked fine....I fail to understand the almost psychotic dislike for them by some members of this forum....
providing the plugs, caps leads etc are fine...
Crud in the carbs can cause the float valve to not close properly, causes rich running at low RPM.
Certainly matches up with the sudden onset, smell of fuel etc. Your fuel pump would probably prevent the puddle of fuel clue that gravity fed bods would get Wink
I would suggest you invest in a replacement set of needles/valves.
I'd bet the clique members lives that thats your problem.
Whosthedaddy
PostPosted: 08:45 - 30 Jun 2009    Post subject: Reply with quote
Stick it on a dyno.
It'll make you smile like a Chesire cat when its belching flames from the exhausts on the overrun and the scream of the top end. This softens the blow of them telling you that its a fueling / jet size problem.
The 7R had used to judder and throw a right hissy fit when I applied the right hand in a mid gear or even as low as 1st and 2nd sometimes. It would bog down, shake the front end, bog down and then go like the proverbial poo off a shovel.
The flat spot was at 4-5,000 revs.
It turned out that it was lean at the bottom end and rich at the top (or the other way round?).
Playing around with the jet sizes may have helped a little to even things out a little but I was more than happy to live with the slight problem.
Pulling away from a slow start and bogging down, that needs sorting.
A dyno run is less than a few rounds of drinks on a Friday night. It gives answers straight away and gives some bragging rights for power / torque...
Visitor Q
$25 whore
PostPosted: 09:12 - 30 Jun 2009    Post subject: Reply with quote
Already been on a dyno, 95rwhp.
Unfortunately, this doesn't just feel like a flat spot which leads to an increased high end.
Plus, on the ride home yesterday it was bogging down below 8k. It's getting worse :O
Although it got a bit better when I chucked in another tank (and watered down what must of been VERY strong redex concn)
Irezumi aka Reuben
Carrot Top
PostPosted: 09:41 - 30 Jun 2009    Post subject: Reply with quote
Bad plugs/lead normally show up as problems when higher up the rev range.
Probably carbs like you originally thought. Needles can go after a while (I think yours is an older bike that correct?) in which case needles can sometimes need changing, or very carefully smooth off the ends. Some people think that's stupid, but it works.
bladerunner
PostPosted: 10:00 - 30 Jun 2009    Post subject: Reply with quote
what the hell does burbling mean? is it not running on 4 all the time..and if it's running rough up to 8K now...not long till it wont start if it is plugs. did you fit cooler plugs than std? I know I had to go a grade hotter on the old blade after it was dynojetted as otherwise it just killed the plugs in a matter of weeks
filing that....check your airfilter aint clogged...the carbs are clean and set up correctly see if they need balancing even if it's just been done....the ht leads aint shorting out somewhere...usually when it's raining that one etc etc
temeluchus
PostPosted: 10:21 - 30 Jun 2009    Post subject: Reply with quote
Redex can shift crap through fuel filters etc so not dead keen on its use.
I think you need to get your carbies off for a clean as soon as you can
Visitor Q
$25 whore
PostPosted: 10:25 - 30 Jun 2009    Post subject: Reply with quote
Like when it is just going on reserves. If you let off the throttle then go back on again, you no it does that weird asthmatic gasping thing. Yeh, well that. I thought it was a fairly well known term.
Not certain if they were cooler or not. Loathe to buy a new set (of standards) just to suck it and see Thinking
Really hasn't been long since I did it thoroughly, and as I mentioned it has no problems high up the range (where it needs more fuel and air).
So, carbs (as I thought), or plugs Thinking
Meh, might just book it in and nab a courtesy bike. Got four days off this weekend, so tempting. Don't want them to fix it, just tell me what it is.
Was worried it was my bodged fuel pump. Well, semi bodged. Same model, ish, and I swapped the connectors by junction boxing it Laughing Works fine so far, but always a slight niggle when it misbehaves.
Mr Hammers
PostPosted: 10:44 - 30 Jun 2009    Post subject: Reply with quote
On the NSR it seemed to go better with an Iridium plug, but it's the opposite in the Bandit. They ran ok, but the difference when I put the originals back in (the ones with the double electrode arms, one either side of the electrode) was quite amazing. A lot more pulling power. I don't dislike them now, but I won't be using them in the Bandit again.
A Guide To Powerbands
mr rip
PostPosted: 11:26 - 30 Jun 2009    Post subject: Reply with quote
when was the airfilter last cleaned/changed?
it sounds like a blocked or choked idle/pilot jet, or the air ways surrounding them, making it run too rich at the bottom end,
my armstrong gets a bit fluffy at the bottom of the rev range when the air filter's due for a clean,
it can make riding in traffic a nightmare as you wind it on & nothing happens untill you give it some more & it takes off
if it's the air ways, redex wont help, they'll have to be blown out with an airline
never criticise a man until you've walked a mile in his shoes, then when the muck hits the fan you'll be a mile away & you'll have his shoes
Visitor Q
$25 whore
PostPosted: 11:39 - 30 Jun 2009    Post subject: Reply with quote
Aye, it was just incase there was crud in the carbs that might be simply shifted.
Was thinking it could be the ram air inlets... Thinking
Will rip the tank off when I get home from work (if it makes it there and back) and have a look.
Anyone reckon whatever this is can cause damage by my riding it? Or will it just run like shite?
Another weird thing, seems to run absolutely spot on for the first half mile Neutral Which makes me think plugs to be honest, as it would have to be something getting hot Thinking
mr rip
PostPosted: 12:05 - 30 Jun 2009    Post subject: Reply with quote
it runs better at first because it's acting like the choke is on but when it gets warmed up it's just too rich & so it starts to misbehave
Finglonga
PostPosted: 12:17 - 30 Jun 2009    Post subject: Reply with quote
Never heard it used in that term, do you mean it is hesitant?
Andy Sez....
F.Y.Y.F.F.
bladerunner
PostPosted: 12:48 - 30 Jun 2009    Post subject: Reply with quote
Hmmm if it was plugs then they usually start off bad and maybe get a little better once warm. Honda type plugs are bad for going west if the mixture is rich and once flooded they don't come back to life so well as most plugs do!
Burbling to me is the kinda noise a V4 or V8 chevy engine makes Very Happy
Visitor Q
$25 whore
PostPosted: 17:46 - 30 Jun 2009    Post subject: Reply with quote
Note title Wink JUst the sound, to me, would be burbling. But yes, hesitant.
The weird thing is, it barely seems to affect performance. It's not lurching about, and the bikes not been (more) unstable when it happens mid corner Thinking
It just really sounds/feels like its dying.
Not so good.
Honda reckoned 150+ vat + coolant to CHECK the needles. I think not.
temeluchus
PostPosted: 17:08 - 02 Jul 2009    Post subject: Reply with quote
its not going to be the needles.....
its gonna be crud in your float bowl....
Visitor Q
$25 whore
PostPosted: 19:47 - 02 Jul 2009    Post subject: Reply with quote
Funny you say that, because now the redex has been through it feels a lot better (wasn't happy with a whole shot in there though, needed diluting).
Haven't had a chance to check my airfilter yet (still can't see how it is that but meh, worth a looky)/
Here are the sparkplugs, and a close up off number 3 cylinder's plug, which has a black ring rather then white Thinking
Any things I can do to clean them up/restore them to glory? Just so I can narrow things down?
Will have to pencil in some time to clean the carbs out at this rate Sad
Blue_SV650S
PostPosted: 08:19 - 03 Jul 2009    Post subject: Reply with quote
If it is just one plug, then its not the airfilter!
So its either a faulty plug/HT/cap or the jetting on that carb.
temeluchus
PostPosted: 09:06 - 03 Jul 2009    Post subject: Reply with quote
*bangs head against desk* The jetting wont spontaneously change will it? the only suffer if the emulsion tube/needle wears (and that would affect all the carbs, and wouldnt cause this severe an issue) or one of the jets fell out of its holder in which case he would have entertaining but obvious flames coming out the pipe.
Still-its probably crud preventing the float valve from closing.
Check that water hasnt gotten into the HT cap as well-look for the charactersitic blue rotted copper.
Visitor Q
$25 whore
PostPosted: 09:24 - 03 Jul 2009    Post subject: Reply with quote
So do you think its just number 3 cylinder that is occasionally running rough, which is why it isn't affecting performance /that/ much when it (briefly) happens?
Ok, will WD40 the crap out of the HT leads.
Does that plug seem indicative of a problem for certain? Can I escape cocking about with the airfilter whilst hungover?
How do I check the HT leads are working WELL. I could stick a spark plug in each of them and check it has a good spark against the frame... but as mine still starts and runs fine most of the time Thinking
The last post was made 17 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.01 - MySQL Queries: 16 - Page Size: 147.74 Kb
