| binge |
 binge Emo Kiddy
| bmwsport |
 bmwsport Nitrous Nuisance
| binge |
 binge Emo Kiddy
| salty21 |
 salty21 World Chat Champion
 Posted: 22:14 - 03 Jul 2009 Post subject: |
if its like the nsr, rs barrels it will be nikosil plated which means a rebore would require re-plating which cost's around £100 so not really worth it unless new barrels are considerably more than that. ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
94 CB400 Super Four ---- 2000 VTR SP1 (sold) ---- 08 ninja p8f(sold, meh) ----05 CBR600rr  |
| stevo as b4 |
| Blue_SV650S |
 Posted: 10:32 - 04 Jul 2009 Post subject: |
What makes you think it is not producing the power?
Before buying stuff, you need to measure the old stuff ...
A worn 2-stroke normally shows signs of 'blow past' on the piston. i.e. just below the ring/rings you see carbon build up where some combustion gasses have passed the rings. These build up over time. A fresh engine won't have this, a long in the tooth one will.
Also measure piston ring end gaps - and look at the 'hone' marks on the bore. If you can't see any, its tired, if they are obvious, then its fresh.
The TZR has a powervalve, I seem to remember you talking about fitting a servo. So I assume you have the motor with the valve close? In that state it'll produce ~12hp right? IIRC on the TZR you can manually set the valve to fully open. This will leave you with a hole in the mid, but allow the full 24odd horse when she comes 'on pipe'
Oh and if you have put this motor in another bike, have you kept the original TZR pipe/expansion chamber? If you haven't - no wonder it is gutless!!  ____________________ The purpose of life is to fight maturity. |
| binge |
 binge Emo Kiddy
The last post was made 17 years, 36 days ago. Instead of replying here, would creating a new thread be more useful? |
