XF 650 CUT OUT
Karl Bird
PostPosted: 18:00 - 04 Jul 2009    Post subject: XF 650 CUT OUT Reply with quote
My Freewind cut out today after about a 50 mile run I was slowing down for some lights when it happened it started again after a small pause it's never done that before im hoping it's down to the hot weather should i worry ? Neutral
carlperkins00...
PostPosted: 18:19 - 04 Jul 2009    Post subject: Reply with quote
do you have a heat indicator (i dont know the proper word for it)
if you do.. how hot was it?
because my hornet got so hot the other day that it had trouble pulling away and started bogging down. if it had got much hotter it probably would have cut out.
riding at slow speeds in hot weather causes too much heat.
if it gets hot and starts bogging down either ride very fast or stop in the shade and leave it for abit.
temeluchus
PostPosted: 19:11 - 04 Jul 2009    Post subject: Reply with quote
Did it stall when you stopped or did it cut out on the run?
When you tried to restart did you have to turn it over for a while or did it start instantly?
If it took a while to restart then its likely to be aheat related issue particularly as you're running an aircooled bike.
Karl Bird
PostPosted: 21:24 - 04 Jul 2009    Post subject: Reply with quote
No it does not have a heat indicator but it was hot today here in Brum the bike cut out while slowing down for traffic lights and started as normal after I had pushed it out of the way of the traffic.
Karl Bird
PostPosted: 21:26 - 04 Jul 2009    Post subject: Reply with quote
temeluchus
PostPosted: 12:43 - 05 Jul 2009    Post subject: Reply with quote
Probably a bit of overheating then.
Where is sunny brum do you hail from? Im in the lovely borough of Woeley castle
Karl Bird
PostPosted: 15:22 - 05 Jul 2009    Post subject: Reply with quote
I'm Gonna do a oil change might help a bit even though it's not due yet. I'm from Hodge Hill by Castle Brom junction 5 of M6
The last post was made 17 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.27 - MySQL Queries: 15 - Page Size: 51.41 Kb
