Where does oil go :) -- Lifan 125
n00biker
PostPosted: 08:35 - 04 Jul 2009    Post subject: Where does oil go :) -- Lifan 125 Reply with quote
Hi,
I have a 2008 model Lifan 125 (Honda CG125 replica I think). The engine window shows the oil level is at minimum.
I didn't get a handbook so I'm not 100% certain *where* to topup the oil.
Here is a picture:
https://imgur.com/oCKXG.jpg
The arrow is pointing to what I *think* is the dipstick.
Here is a picture with the dipstick removed:
https://imgur.com/tAIRp.jpg
Also, what type of oil should I use?
Really appreciate any advice... cheers
iooi
PostPosted: 08:48 - 04 Jul 2009    Post subject: Reply with quote
Oil in that hole Thumbs Up
Just top it up slowly to give oil chance to sink to the viewing window, or you could end up over filling.
Any 10-40 or 20-50 should do. Just avoid stuff like Magnatec.
Perhaps the best bet would be to change the oil and put some fresh in there. THe amount you need is usually stamped on the case around the filler hole Thumbs Up
Zeeky
PostPosted: 08:55 - 04 Jul 2009    Post subject: Reply with quote
yep that looks right, the oil goes there!!
and with the type of oil, i rekn any 4 stroke oil would do, make sure its multi grade..!
something like 15W/40 ...
that Should do it!! Very Happy Exclamation
WoooHooooooooo!!!!!!!
Knacker
PostPosted: 14:28 - 04 Jul 2009    Post subject: Reply with quote
Personally i would go for a 10w40 Mineral oil .
As said avoid overfilling or it will do a shed load of damaged, If you think you have overfilled, just undo the sump plug and let a bit out until its just Max level.
Previous: K1 GSXR 1000
TUG
PostPosted: 18:50 - 04 Jul 2009    Post subject: Reply with quote
It would only damage the bike if he put half a litre too much in... a little bit wond do any harm, stunt riders overfill their engines to prevent starvation but at the same time their engines dont pop as soon as they are being ridden flat whilst mid burnout. Thumbs Up Wink
Haz ER-5, innit!
The last post was made 17 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.44 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 44.08 Kb
