Big Bore RS
Damon
PostPosted: 16:19 - 04 Jul 2009    Post subject: Big Bore RS Reply with quote
Hi all,
Just a quick update, After blowing a hole in the crankcase big enough to fit you fist through on the 750, I am back to riding my mean, green, lawnmower machine.
It's coming to that time where a top end rebuild is in order. I have done a few of these before so I think I might bite the bullet and go for a big bore kit. I just have a question regarding carbs. Can I use the standard Carb the RS125 comes with or do I have to run a 34mm carb.
Thanks in advance and I hope everyone is well.
Damon Thumbs Up
Coxyzxr
PostPosted: 16:39 - 04 Jul 2009    Post subject: Re: Big Bore RS Reply with quote
Dam0n wrote:
Hi all,
Damon Thumbs Up
Sorry to stray away from the topic but how did you manage to blow a hole in the crankcase on a zxr? what was the milage on it?
My eyes do not believe what they are seeing, I eagerly await your response! Sad
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
temeluchus
PostPosted: 18:19 - 04 Jul 2009    Post subject: Reply with quote
I dont think youd HAVE to use the bigger carb. Depending how much bigger you go it may restrict it a little but it will work. Almost certainly need some jetting tho.
PostPosted: 18:59 - 04 Jul 2009    Post subject: Reply with quote
You could probably either carb. The 34mm carb might well help, but the big bore kits are unlikely to give massively more power (although often a better spread of power) and should still be within reason for the 28mm carb.
Not sure for road use I would bother with a big bore kit on a 125. But then riding a 125 is a choice and I like the silly way of producing power.
bmwsport
PostPosted: 20:16 - 04 Jul 2009    Post subject: Reply with quote
yea i wouldnt bother going for big bore kits, from what ive read they dont seem to be that much better, i'd have a look at a 34mm carb, v force reed block, forged piston, vhm head, decent exhaust if you dont have one already, should be plenty enough.
Damon
PostPosted: 22:48 - 04 Jul 2009    Post subject: Reply with quote
ok thanks all, I'll just go for a standard barrell and piston i think.
And coxyzxr, I was riding down the A217 and accellerating hard from each set of traffic lights. I accellerated from one set of lights and heard a small bang. The bike started sounding like it had no exhaust once it got about 5 - 6k revs. I slowed down and turned her round. It was all going well until I hit a red light just at the start of the mad mile. This is where I went wrong. I should have crawled home to live another day, but no, I decided to pin the throttle and cane it. I got to about 1**mph and it just let go. A rather loud bang followed by a smokescreen and a full pair of boxershorts. Thumbs Down I dont think I should be aloud out of the house sometimes...
Coxyzxr
PostPosted: 23:03 - 04 Jul 2009    Post subject: Reply with quote
Well at least you had the balls to crack on mate.
What was the milage on the engine? Was it well serviced?
The 7 engines are second to none and do take serious abuse before blowing up.
I'm on a 91 zxr with pretty much no history and 47,000 miles and as far as I know nothing but standard oil changes yet she still manages to pull book speed on demand (don't I know it Rolling Eyes ) which tbh is a good feat of engineering if you ask me.
And thh if someone said to me "lets go tour europe for a fortnight" I'd be like, "ok I'll give her an oil change, pack a couple spanners just in case and lets move" I'm that confident on the engine. If the engines sound the rest is trival in my eyes Smile
Kind regards.
bladerunner
PostPosted: 00:00 - 05 Jul 2009    Post subject: Reply with quote
I've just rebuilt an rs125 with a polini big bore after the crank went south on the std 125 motor. the 125 top end was spotless rather lucky seeing as the big end went at a steady 70 on the duel carrageway. I must say the 154 kit with a 28mm carb does not have the top end zing after 10.5K compared to the 125 but the mid range is LOADS better. almost like riding a proper bike and it does wheelie a lot better with the torque. But for the money.....£380 just for the big bore....is it really worth it?
if I was back on a 125 then yes it's loads more fun in general day to day use as you have a choice of gears to be in but on std gearing it still has the same top end as the 125. Thats running a tyga pipe with std needle and now running a 132 main jet. the needle jet in the BB instructions was just too rich (x17) and it does vibrate a fair bit more as well
Damon
PostPosted: 21:05 - 05 Jul 2009    Post subject: Reply with quote
Kind regards.
Nice, she had 27,000 miles on the clock and was serviced regularly. just one of those things i guess. i hate the 125, cant wait to get back on a bigger bike. thanks for the input guys
Damon
The last post was made 16 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 15 - Page Size: 65.98 Kb
