| funmonkee |
 funmonkee Super Spammer
 Posted: 16:50 - 05 Jul 2009 Post subject: XT Engine troubles,,, Gubbed 5th gear? |
Not sure exectly what has happened, but my MZ baghira is behaving oddly since yesterday. I overtook another bike at a fair speed, parked up minutes later, noticed a small pool of oil. Also noticed a missing bolt from my engine casing (cover of the starter).... refilled with oil, seems okay till 5th gear
...Bike acts normal until I get to 100 - 120 KPH, I then switch to the 5th gear and I should be able to reach 140- 160 without too much trouble... However, as soon as I hit 5.1k revs in 5th gear the bike judders forward and back. I know this bike has a rev limiter, but that's supposed to be 6.5k... Grrr
Could there is something wrong with 5th gear? Long shot, but it's worth asking if any of the above points to a gearbox problem?
Anyway, off to give it an oil and filter change, just becuase I had to temporarily put some 10w40 in it... the manual says 10w30...which I've now got  ____________________ **** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
| funmonkee |
 Posted: 20:53 - 05 Jul 2009 Post subject: |
Changed oil and filter. No leaks. Engine feels smoother with new oil Still no chance on the judder forwards/backwards at 120KPH/5.1k revs in 5th gear
It's not as If I need over 100KPH for my daily commute; but when I have to hit the bypass I need 120/140 KPH to make good progress through the traffic.
Any ideas
I'm going to replace the spark plug tomorrow- see if it's a spark plugs issue ( grasping at straws) ____________________ **** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b] |
| robocog |
 robocog Traffic Copper
| funmonkee |
| funmonkee |
 Posted: 22:42 - 06 Jul 2009 Post subject: |
Didn't get a chance to check the spark plug (clutching at straws...), but did adjust the chain and check the oil. Took the bike out for another test and it's still the same. It pulls fine and smooth (for a single) in 1-4th gears, but when you get to 5th gear and 5.1k revs it starts to judder and fairly regularly pops and bangs too
I've changed the fuel twice since this has started.
Next I'll look at
change the spark plug
check the fuel lines to ensure they are clean/clear
kick it ____________________ **** Don't ride faster than your angel can fly Get this Free Space
| Gawain |
 Gawain Nitrous Nuisance
| Itchy |
 Itchy Super Spammer
 Posted: 08:49 - 07 Jul 2009 Post subject: |
XT600 engines from the 3AJ up to the 3TB (the 4PT didn't have this problem) , and derivatives of ie the 660 watercooled jacket version suffer from 5th gear pitting problems around 3-40,000 miles , my XT600 out here in Mongolia has done 23000 , and once Russia it out the way will be sitting on 30,000 miles and may need to be rebuilt on the gear box.
David Lambeth knows how to fix the 5th gear pitting problem costs a couple hundred quid , considering he rips the engine outs the frame and reassembles the gear box its not bad value.
He has however gone on vacation for the next 4 weeks , and thus is uncontactable for a while, though the solution an XT rider I found in Mongolia is to not use 5th. 4th is plenty enough to get you to 70mph obviously costs more fuel , why the hell you would want to go to 100mph is beyond me the vibes at 70mph are quite bad 80 really bad, 90 and your vision goes blurred. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| funmonkee |
 Posted: 09:13 - 07 Jul 2009 Post subject: |
So, I should look for a XT660 gearbox
Thanks dudes, that's what I need to hear. I'm happier taking out the engine of the MZ than I would be any other bike...a single seems so much simple, or am I asking for trouble......
I need to be able to overtake on the bypass therefore any extra MPH above 70 is advantageous ..but I do agree, it vibrates a hell of a lot at 80+ ____________________ **** Don't ride faster than your angel can fly Get this Free Space
| funmonkee |
| funmonkee |
 Posted: 13:37 - 11 Jul 2009 Post subject: |
YIPPEEEEE
I sprayed the carbs with carb cleaner and also remove the stiopid tarty airfilter I had put on months ago...
...now all is well and the bike operates as it should... easily gets to 160KPH in 5th...and still has more
Moral of the story... check all the shite you put on your bike first; check all the easy stuff  ____________________ **** Don't ride faster than your angel can fly Get this Free Space
The last post was made 17 years, 43 days ago. Instead of replying here, would creating a new thread be more useful? |
