| teasser |
 teasser Derestricted Danger
| prawny1 |
 prawny1 World Chat Champion
| bladerunner |
 bladerunner World Chat Champion
 Posted: 01:02 - 08 Jul 2009 Post subject: |
As prawny said. If you machine the material from the bottom of the barrel then you lower the ports so thus droping the power lower down the rpm. Remove it from the top of the barel or indeed the head and you keep std porting..but doubt you can remove anywhere near 3-4mm without MAJOR piston/head hitting each other issues! Usual trick is to measure your squish and set that to around 0.8 mm or fit thicker base gaskets to raise the ports and machine the heads to suit....hardly worth the effort on a ped though to weld the head and machine a better squish and head profile and the such  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| hmmmnz |
 hmmmnz Super Spammer
| teasser |
| teasser |
| stevo as b4 |
 Posted: 21:58 - 11 Jul 2009 Post subject: |
I had 0.5mm skimmed from the head face of my old speedfight 100, ages ago. You do need to properly measure the squish before hand, to make sure that there will not be any piston to head contact. Also increasing the compression ratio to far will likely cause detonation, and as you cannot alter the CDI advance curve, you would need to try crude methods, such as using a 1grade cooler plug, and super unleaded fuel and or octane booster.
My SF100 did go alot better off the mark with the compression ratio increased from 6.7:1 to 7.2:1 (corrected), but it was no quicker flat out, (maybe even felt a bit flatter) but was just better at picking up from low speeds. I still had 1.3mm of piston to head clearance after the head was fitted, but i used a cooler plug and 98RON fuel soon after, as i seized it on the second ride using std 95RON fuel. |
The last post was made 17 years, 91 days ago. Instead of replying here, would creating a new thread be more useful? |
